#19 | |
Knower of little
Drives: None Join Date: Jul 2019
#20 |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Great work mate. I've got to do something about the rust on my car. I'd be interested to see how the paint you used holds up. I have heard some horror stories of people using paint where the rust either comes through the paint or its still rusting away underneath the paint.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#21 | |
Knower of little
#22 |
Knower of little
Small Update
Nothing too terribly exciting since the cars been drama free. I did some maintenance this weekend as well as stopped by the local junkyard and got a 1.8L throttle body and a neat shift knob from a scion TC. photo5039614750413138034.jpg The throttle body came off an 04 Matrix and isn't even remotely close to working. I can adapt the cooling lines to work but not much else so that idea is out the window (unless I find a newer 1.8 to steal a TB from) But the shift knob is on and looks good, better than the ebay special one I had on previously. photo5042335603605219456.jpg |
#23 |
Knower of little
Updates
I'm slowly chipping away at my to-do list over the past couple weekends. Firstly let me explain my reasoning behind most these mods. I hate cars that feel cheap, and although yaris' are cheap global platform cars, they don't need to feel cheap. Boring Maintenance Done: New serpentine belt, new rear lift supports, bilstein rear shocks (matching fronts will come later), weathertech floor mats, fixed the roof wrap, and cleaned all the ground wires I could find. The center armrest is just hollow plastic, so I put some junk hardware in it and then filled it with expanding foam, to give it some weight and an overall better feel. photo4936099454394673328.jpg photo4936099454394673327.jpg I swapped all the speakers in the car and replaced them with JBLs. Took me a while to figure out how to mount them and to get them all in phase with each other but they bump now, so really happy about that. Also added more sound deadening while I'm at it. (mostly to help remove the cheapness sound when you close the doors and road noise.) Before Jan3 (5).JPG After Jan3 (7).JPG Another cheapness thing I dislike is the horn, it sounds like a bumper car. I robbed a set of horns and bracket off a subaru (from 2009+ models) at the junkard and installed them. (they also happened to be the same brand and one was even the same model number as the yaris one.) They bolted right in and I only had to trim a little of the air dam and solder in two plugs (they SHOULD have a relay and a power source but I can't be bothered.) Also I will probably modify the front bumper before reinstalling but I haven't gotten to it yet. Before Jan3 (10).JPG After Jan3 (12).JPG |
#24 |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
You gotta go air if you want a real horn
![]() ![]() If you get the chance, try 2003-2008 dodge ram horns they're pretty loud and have a good angry tone
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
#25 |
Knower of little
Hahaha that's so excessive, I love it! So far they sound fine, we'll see how they are in use. I have caddy horns on my other car and they're nice, but those definitely need another power source.
#26 |
The thing I like about the air horns is that the big rigs can hear you just before they kill you lol
#27 |
Knower of little
Quarantine Updates
This was all done over the past few weeks during this lock in period. Maintenance: Trans flush with new pan gasket and filter Engine oil flush and new oil pan gasket First wash, wax, and seal in like 10 months photo4945510213071513641.jpg Mods: Started restoring the junkyard Konig 15x7 rims I got a while back, no tires yet so won't be installed right away. 35% tint all the way around photo4942902910224803983.jpg photo4942902910224803984.jpg photo4942902910224803985.jpg |
#28 |
Looking really nice. What do you use for a paint sealer?
#29 |
Knower of little
#30 |
Knower of little
More Quarantine Updates
Not particularly exciting but I got the front strut assemblies swapped as well as the sway bar links. Ended up cutting the old sway bar links off because the hold it with an Allen key while loosening with a ratchet process was too tedious. Also, got to love working on sub-compacts where you have to remove the entire cowl unit just to access 2 bolts. photo5033271083716946069.jpg |
#31 |
Knower of little
Update
Might as well try to make the best of this quarantine by getting caught up on maintenance. To start off, the first issue/reason for doing work is the trans drain plug gasket was seeping a bit of fluid, so I bought 2 magnetic drain plugs to replace the awful OEM hex head bolt. I already replaced the engine oil one with a magnetic Mishimoto plug, but the one I got for the trans (MMODP-1815B) didn't really fit, I wasn't happy with the slight resistance to threading in, so I opted to use the Dorman (090-114CD) one instead. DSC_0005.JPG DSC_0006 (3).JPG I also took the opportunity to replace all the coolant hoses, thermostat, and rad cap with the ones shown below. The 22556 was a cut-to-fit and didn't fit worth a crap so don't buy it. The coolant also didn't look terrible for having 109k on it but still worth doing it since I'm past the service interval. ALSO: Do yourself a favor and DO NOT try to re-use the OEM clamps, just buy new ones. I fought with them for over an hour trying to get them to lock in the open position but ended up cutting off the little ears that was stopping them from opening all the way. DSC_0002.JPG DSC_0004 (2).JPG |
#32 |
Knower of little
End of the World Update
Unfortunately I've been unmotivated to do more with the car during this whole end of the world thing but I finally got around to trying to get rid of the stale food smell that came with the car from the previous owner. I already shampooed the interior but the next step was to remove the seats and do a more thorough job. photo4915942331060955304.jpg It might have been a mistake to use a 700+ ft lb impact gun to remove small E10 seat bolts. Ended up snapping off two of the rear seat bolts so I had to unbolt the seat from the rail to get the seats out. photo4915942331060955303.jpg |
#33 | |
#34 |
Knower of little
Gotta Pass Inspection Update
Good New; The stale food smell is pretty much gone and I may have found Subaru seats that will fit the car (more info on this as I find it) Being that my inspection is due this month, I worked up the motivation to fix the exhaust leak. Which is located in a really common place for exhausts to blow out, right where the hanger weld is in front of the muffler. photo4936170179621136484.jpg I bought the aftermarket "exhaust repair pipe" which was clearly copied from a blurry fax of the original design because it doesn't really fit Aftermarket PITA #1 The bolt holes in the flange don't allow the spring bolt to go through it, so I had to drill them out to work. photo4936170179621136483.jpg Aftermarket PITA#2 The section of the stock exhaust that the repair pipe is supposed to attach to is oval, so now I have to squish the original part of the exhaust into a circle so I can weld it nicely (we'll see how that goes later today) photo4936170179621136482.jpg |
#35 |
Knower of little
I'm not going to show the weld because it was hideous. However, I got it sealed and I was able to bend the existing pipe into a circular shape by tightening down a standard exhaust clamp on the "peaks" of the pipe every 1/2in or so, which allowed the old pipe to slip in into the new pipe. Not a pretty fix but functional so good enough.
#36 |
Knower of little
Update
To start off, my car decided it didn't want to have trans fluid in it anymore and in the time it was sitting, most of the fluid drained out so I went to run errands and it wouldn't even drop into gear. Thanks in part to me using a trans pan gasket instead of RTV. The gasket broke around most of the bolt holes and blew out entirely in the rear of the pan. So I installed a new pan (old one had a big dent) and also put in the factory drain plug back in, the longer magnetic plug was interfering with some part in the trans which also made it so I couldn't accurately torque the pan bolts down last time. So in summary, don't replace the trans drain plug and don't use a gasket for the trans pan, just rtv it with something rated for trans fluid. [ATTACH]photo5048638867544057980.jpg[/ATTACH] |
| 2012 Audio Upgrade FAQ and Build Log | muffin_top | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 01-19-2022 07:28 PM |
| Build thread! '08 Yaris Hatch | nimuntak | Photo-Video-Media Gallery | 105 | 01-28-2014 03:28 PM |
| The open political discussion thread. Read the first post! | eTiMaGo | Off-topic / Other Cars / Everything else Discussions | 342 | 09-15-2009 01:34 AM |
| Aftermarket rim thread vs official wheel guide | regal | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 04-01-2009 01:11 PM |
| Post Whores-aka Yaris chat thread | Black Yaris | Off-topic / Other Cars / Everything else Discussions | 21 | 07-12-2007 06:37 PM |
