![]() Drives: 2010 Yaris Sedan Join Date: Mar 2018
Oil Filter Concerns
Ever since I purchased by 2010 Sedan I have used the Toyota 90915-YZZF2 filter. Used the last filter out of my existing case, ordered another case from the vendor, received part number 90915-YZZN1. Changed oil as normal without realizing the different filter, was greeted with a brief engine rattle on starting up which had never happened prior. Then I checked and realized this was different item. My vendor indicated the YZZF2 has been superseded by the YZZN1. Can someone confirm this is indeed the case?
Thanks! |
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
yes its a replacement part number as the facility has changed where the oil filters are made, nothing to worry about my man, im a master technician at the dealership
Good Deal, Thanks!
3 Yaris and counting..
For extra piece of mind, prime the filter before install. It should minimize tick on startup.
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Fram Ph4386 or Ph4967
Supertech st4386 or st4967 There isn't a larger filter for the same price as stock garbo filter, change my mind |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Fram is trash, I wouldn't put that garbage on a $500 plow truck.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#7 | |
I've never heard or seen someone show a catastrophic failure of an oil filter. Just monkeys tightening them with wrenches until the gasket splits The cheaper the filter is made, the better. I can't afford to spend my time on trying to stab through a beefy oil filter that can't include the non slip coating. Fram spins off toolless. That's invaluable to me I get confused when people have such a strong stance on filters but the reasoning is piss poor. If you have any reason to hate fram, please chime in. I have no brand loyalty whatsoever and will switch to your filter brand if the value is there |
![]() ![]() Drives: 1983 carina 2NZ-FTE Join Date: Dec 2020
90915-yzzj3 filter also fits yaris and flows better.
more same type filtermaterial
#11 | |
Gen 3 > Gen 2
#12 | |
Gen 3 > Gen 2
Good for you. I'll stick with OEM approved filters.
#14 | |
I think the first oil change, i got it off with channel locks. After that was a breeze because i make them hand snug |
i have proof in the form of experience, cars coming in the dealership that have been maintained with aftermarket parts compared to oem just have more issues, plain and simple, a good example is i had a tacoma with a fram filter and they came in with drivability and intermittent misfires concern, oh hey, take a wild guess, the camshaft gear strainer was clogged full of debris that the oil filter was clearly ignoring, pulled apart that oil filter and the actual filter wasnt even retaining its round structure, it was "folded" so to say inside the filter housing, total garbage parts that could quite literally ruin your engine.
#16 | |
Gen 3 > Gen 2
I usually run Bosch filters or Wix if I can't get my hands on an OEM Denso filter for whatever reason.
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
Just lurking on this thread. I have seen some Cut away oil filter videos and the inconsistency of fram shocked me, Pleating, glue and rust problems... yipes.
I use the wix, 51393XP full synthetic filter. It is larger than "stock size" with more filter surface and ads a bit of volume to the oil supply (~10-15%). $11.00 filter for a $4.000.00 engine. I will play those odds. I do use the supertech 10,000 oil from wallyworld with no problems. SAE is SAE! One the light goes on at 5,000 the oil gets changed! I will not mess with filters or oil because cam phasers/ adjustable cams need clean oil! |
#18 | |
Gen 3 > Gen 2
WIX is top notch, ive actually switched to their filters exclusively now.
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| 2009 oil filter | lcpete | DIY / Maintenance / Service | 10 | 04-05-2012 08:05 PM |
| Oil & Air filter change please help! | JAMMAN1701 | DIY / Maintenance / Service | 2 | 04-01-2012 09:28 PM |
| Higher capacity oil filter???? | 2006fronty | DIY / Maintenance / Service | 29 | 01-06-2009 02:00 PM |
