Old 03-04-2012, 10:51 AM   #73
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by ASG14 View Post
DING BRAKES ARE DONE
Oh, my '96 Camry. Who wants a braking competition?
I will take you up on that :)
I just did an BBK using OE parts as well
stock fronts were 288, I found 325mm off an A6
stock rears were 245, I found 300mm A4 Conv
cool thing was I got to keep my calipers, only had to replace rotors and caliper brackets, and I threw a fresh set of Euro spec pads
Old 10-05-2012, 02:50 PM   #74
enviri
enviri's Avatar
Drives: 2010 Yaris
update on bbk, did a checkup after 30k miles and the brake pads are still pretty damn new. everything is working fine and wearing nice and even.
Old 10-25-2012, 04:06 PM   #75
mario98c
mario98c's Avatar
Nice!
Old 10-25-2012, 04:15 PM   #76
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Awesome another brake option.
Old 07-08-2013, 09:48 AM   #77
kou
Drives: 08 lb
Just upgraded mine over the weekend. My first brake job on the yaris 102,000 and still had some pads left but warped rotors. Total cost $380 OEM pads for 2009 corolla rebuilt calipers for 2009 corolla and rotors from the yaris se. Wheel size is 15x7 et42.
Old 07-08-2013, 10:20 PM   #78
enviri
enviri's Avatar
Drives: 2010 Yaris
Woo!! 2 in the northeast! now go persuade james to do it lol
Old 07-08-2013, 10:37 PM   #79
kou
Drives: 08 lb
Haha I will try. Now I need some rear disc brakes.
Old 07-08-2013, 10:38 PM   #80
enviri
enviri's Avatar
Drives: 2010 Yaris
i'll keep a look out for you.
Old 07-08-2013, 10:41 PM   #81
ASG14
Camry Owner
Drives: '96 Camry XLE 1MZ-FE
Send a message via AIM to ASG14 Send a message via MSN to ASG14
AWSOME!
ASG14 is offline   Reply With Quote
Old 02-05-2015, 05:17 PM   #82
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Originally Posted by seth_man View Post
piston diameter is larger on xd/corolla calipers, therefore move fluid volume is required to move the piston the same distance, it takes a longer master cylinder stroke to move more fluid and create the same pressure at the brake pad. in all reality we prolly should be upgrading to a larger bore diameter master cylinder to go with this caliper upgrade. our master cylinder bore diameter is 13/16" and the xd master bore diameter is 7/8"
I'm gonna revive this thread awesome info!
Think I'll swap the master cylinder also! Corolla and XD are they the same?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 02-05-2015, 06:37 PM   #83
enviri
enviri's Avatar
Drives: 2010 Yaris
47201-52420 -> scion XD
47201-02490 -> corolla XRS 09
Old 02-05-2015, 06:45 PM   #84
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
will they mount properly on the Yaris is the question, for a rear disc swap corolla XRS should be the best
R-CaT
Project Yar 2ZR
Old 02-05-2015, 09:08 PM   #85
enviri
enviri's Avatar
Drives: 2010 Yaris
most likely not lol.
you *MIGHT* get away with using the scion's master cyl,
and i know the brake booster off an xd will plug right in...
44610-52620
the XRS booster assy looks sooo different.
44610-02441
Old 02-06-2015, 09:09 AM   #86
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Originally Posted by Jason@SportsCar View Post
Bigger (diameter or heavier) rotors will effect the cars overall performance. Putting bigger rotors on is the reverse installing lighter wheels, flywheel or an under-drive pulley. It is also an increase in unsprung weight, which effects handling.
But a change like this will not make a discernible difference on the street - except to those that have the oversensitive but-dyno - but it would show up on the dyno and in lap times (a very small time change) at the track. While it can slow the cars acceleration down, being able to repeated stop from high speed could pay off in the long run.
The weight increase is the reason a lot of big brake kits use a two-piece rotor with an aluminum hat. Better stopping without adding weight, win, win.
Since I'm on this let me update info
Yaris rotor 8lbs
Yaris SE rotor 10lbs
Yaris caliper 13lbs
Corolla caliper 15lbs
So for rotating mass there's a 4lbs increase and in overall car weight its 8lbs
R-CaT
Project Yar 2ZR
Old 04-23-2015, 05:36 PM   #87
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
Just picked up a new set of 2011 calipers, se rotors, apex lines and stoptech pads Just need some decent fluid. I cant wait to get these on and see if they handle an open track session.
Caramanos2000 is offline   Reply With Quote
Old 07-11-2015, 04:49 PM   #88
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Got to bring this UP if you are going for the master brake swap from the XD you need the Booster
R-CaT
Project Yar 2ZR
Old 08-03-2016, 01:48 AM   #89
aeipee13
DKDC
aeipee13's Avatar
Drives: Yarlet
Just installed the XD BBk (lol) and would highly recommend it. I did not swap for the XD MC or booster yet but plan to soon. The stock Yaris MC and booster are now the weak point and there is a slight but noticeable loss in break pressure when hitting the breaks hard (not that you ever need to in a Yaris other than to avoid an accident).
The piston diameter size difference mentioned earlier explains the slight fade in pressure perfectly. Also I had never changed my pads or rotors after 240,000 miles and over 8 years my Yaris. The OEM pads and rotors were in great shape considering their age, only a small crack on the pads and a hairline crack on one rotor.
(dick measuring info goes here)
aeipee13 is offline   Reply With Quote
Old 08-11-2017, 09:12 PM   #90
Jerkratt
Jerkratt's Avatar
Soo.. Wakey Wakey XD MC & BB plug n play?
"It hurts more when its wet"
bbk, big brake, big break kit, brakes, jdm
07 YARIS Liftback FOR PARTS benjomothians DIY / Maintenance / Service 0 03-28-2011 01:10 PM
Aftermarket parts and Factory Warranty in Canada? jonathanq Canada 3 07-11-2009 12:17 PM
FS: C-One Parts new & used - Socal 03Z33 Items for Sale by private party 90 06-03-2009 10:08 AM
