Old 02-28-2014, 02:59 PM   #37
longlivekel
Drives: Rover Mini S
Maybe in a year or so.. And if i have room after swap. I am definitely looking at buying one of these!!!
longlivekel is offline   Reply With Quote
Old 03-02-2014, 05:55 PM   #38
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
The tooters are done...
$265 including shipping
You guys on the list have first dibs.
There's still one extra for anyone else who might want one.
Production Estimation List
1. Fredovvti
2. dragoonmc
3. jjwitter
4. Klink10
The longer threaded studs have been ordered, paid for, in transit, and should be delivered any day now. So the tooters will be ready to ship this week.
My PayPal is: greggabi@verizon.net
A personal check or USPS Money Order is also fine.
Greg Mamishian
21444 Entrada Road
Topanga, CA 90290
Greg
Old 03-02-2014, 07:44 PM   #39
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
OMG, they look so awesome...I wanna get one after a while. Not gonna find something like this any where else. They look great TooTer.
I N S T A G R A M- @Hanzo_Stmpng_Grnds
x-Check out my build thread-x
HANZO's Build Thread
HANZO_187 is offline   Reply With Quote
Old 03-03-2014, 07:32 PM   #40
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
picture and list of everything needed to put this on the car please.
longer studs, ect...
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 03-03-2014, 08:54 PM   #41
It's all in the first post.
Old 03-04-2014, 01:40 AM   #42
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Looking great!
Old 03-04-2014, 02:40 AM   #43
tooter
play every day
tooter's Avatar
The threaded rods will be in any day now and I'll take a pic of the complete kit... but it's just basically the spacer, a stock intake manifold O ring gasket, 5 smooth flange nuts, and 5 long metric threaded studs.
The studs and nuts look like this...
...and the gasket looks like this.
The CNC designer perfectly replicated the same exact gasket groove profile as the stock intake manifold to insure a reliable leakproof seal.
Greg
Old 03-04-2014, 06:54 AM   #44
Klink10
Klink10's Avatar
Hey Tooter.....Let me get the funds transfered over to checking and I'll get one to you ASAP. One more question....you had mentioned that one hose had to be lengthened to fit on the tooter. Can you point out which one in one of the pics showing the tooter installed? Got to figure out a clean way to do that. Thanks
Edit: Also are you using Loctite on those studs and without me having to look, what is the torque setting and tightening sequence?
Old 03-04-2014, 12:12 PM   #45
tooter
play every day
tooter's Avatar
There's no rush, Klink. I'll likely be doing more small production runs if needed.
Sure. I'll post some close up pics when I get some time off work. From running the aluminum tooter intake manifolds, my hoses were all switched around so what you'll see will have no relation to the stock setup!
I've never torqued the intake bolts and didn't use any locktite on the longer spacer studs. I just go by feel and snug everything down evenly with a few sequential passes. With all of my intake experiments I've likely taken more manifolds off and on than anyone else here and have never had any issues.
Greg
Old 03-04-2014, 12:12 PM   #46
rexseesyou
Drives: 2009 Toyota Yaris Sedan S
Put me on the list for the 5th 1 but yes can you show a pic of the hose that needs to be modified. Thanks!
rexseesyou is offline   Reply With Quote
Old 03-04-2014, 11:22 PM   #47
tooter
play every day
tooter's Avatar
Someone just sent me money for one, but I have no idea what his screen name is, or whether or not he's on the list.
So to avoid any more complications, right now there are four spacers still available, and from now on it's first come first served.
I'll just keep everyone posted on any changes in spacer availability in this thread.
Greg
Old 03-04-2014, 11:27 PM   #48
tooter
play every day
tooter's Avatar
Hey Rex,
I should have time to take some pics tomorrow.
There's no longer a list and right now there are four spacers in stock.
Take Care,
Greg
Old 03-05-2014, 11:39 AM   #49
3cyltrbo
what affect will this spacer have in conjunction with your intake manifold/
will this spacer fit in the engine compartment for cars that already have your intake manifold?
3cyltrbo is offline   Reply With Quote
Old 03-05-2014, 12:19 PM   #50
tooter
play every day
tooter's Avatar
Yeah, I was thinking of the same thing... but a spacer won't fit because the tooter intake manifold already occupies the free space between the engine and the radiator...
However, the tooter runners are already one inch longer than the stock runners, so it's like having a one inch spacer already built into it.
Greg
Old 03-05-2014, 02:48 PM   #51
tooter
play every day
tooter's Avatar
Here's what I did with the coolant hoses...
simply disconnected them from the throttle body and connected them together with a coupling until I get some longer hose pieces to put them back on.
Then I just hung the loop over the fittings on the throttle body...
I don't live in a cold area so having a heated throttle body isn't much of an issue. That's why it doesn't matter if the car runs like this.
Greg
Old 03-06-2014, 12:00 AM   #52
tooter
play every day
tooter's Avatar
Three spacers are still available,
and this is what kit looks like.
Old 03-06-2014, 01:23 PM   #53
tooter
play every day
tooter's Avatar
Just to let the buyers know... I'm working downtown today, so all of your tooters will be sent out tomorrow, Friday the 7th.
Greg
Old 03-07-2014, 01:47 PM   #54
tooter
play every day
tooter's Avatar
The spacers all shipped this morning at 9:00am by USPS Priority Mail.
The scheduled delivery date for all of them is this coming Monday, the 10th.
Greg
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 09:11 PM
stock scion xa exhaust and intake manifold and others taman86 Items for Sale by private party 0 09-27-2012 03:39 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
