Old 07-17-2019, 10:23 AM   #109
myfirstyota
3 Yaris and counting..
Nope. I'm still not allowed at my apartment. Long story.
This is killing me. I have the other yaris id like to finish before the summer is ovre too but ya know... canadian law is bullshit. Stand up for yourself and get arrested right?
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 07-17-2019, 08:02 PM   #110
Tskm2
Drives: Yaris hatchback 06
Thats bad. Law for what?
Tskm2 is offline   Reply With Quote
Old 07-17-2019, 09:10 PM   #111
myfirstyota
I should have updates in the next month for both cars. We'll leave it at that.
Old 07-18-2019, 08:40 AM   #112
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
Whatever happened sounds like a bummer
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 07-18-2019, 10:40 AM   #113
myfirstyota
Lee, you have no idea. Summer is half over and I haven't even been able to wrench for a single minute. It's KILLING me.
Old 07-18-2019, 05:38 PM   #114
Maritime
Drives: 2008 yaris 5dr hatch
Shit deal. Good luck. I cant scrounge the funds for my tires or Id be rocki g a finished ride.
Sent from my moto e5 play using Tapatalk
Maritime is offline   Reply With Quote
Old 07-20-2019, 10:10 AM   #115
myfirstyota
Ok so it appears I'll be back to wrenching the week of Aug 5th.
Guarantee I will be spending every waking available minute putting these cars together that week.
Lots of updates coming soon for both lifted and lowered cars!!!
Old 08-02-2019, 10:11 PM   #116
myfirstyota
Updates soon!!
I should have the full lift kit installed in a few weeks max.
Just need to finish up the red car first. But as soon as that's done I'll have the time and space to focus on the winter car.
Check back soon!
Old 09-05-2019, 02:02 AM   #117
samuelyaris
Drives: yaris
加油~期待新的消息
samuelyaris is offline   Reply With Quote
Old 09-05-2019, 07:19 AM   #118
myfirstyota
So I encountered a snag. I went to install the front lift plates last weekend and quickly realized the passenger side driveshaft hits the subframe when pushed down too far. I've thought of a solution that involves lowering the subframe by about 2.5 inches. The lower trans mount will have to be custom made, the subframe spacers will have to be custom made, the sway bar links will need to be lengthened and a custom longer steering shaft will need to be fabricated. I'm picking up the materials for the subframe spacers tomorrow and gonna try to get them welded up this weekend. I'm still aiming for a bolt in lift kit. Although now it will involve many more parts.
Old 09-05-2019, 09:45 AM   #119
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
Thumbs up for determination and ingenuity! Hope the additional fab goes well.
Hot Rhonda
- Bayou Blue
- Cosmo Racing Short Shifter
- Kenwood Single DIN Aftermarket Headunit
- Rockford Fosgate Punch 6.5” Speakers
“the dents make her handle better.”
YarMatey is offline   Reply With Quote
Old 09-05-2019, 11:27 AM   #120
Leegamer
Leegamer's Avatar
Does this mean you'll lose 2.5 inches of ground clearance?
Old 09-05-2019, 02:24 PM   #121
myfirstyota
Kinda yes kinda no.
The spring perches in the rear stick down pretty far after the angle of the rear axle was pushed down.
I believe the exhaust is the lowest part under the body of the car.
True ground clearance is measured to the lowest part of a vehicle. Usually the differential in say, a 4x4 truck.
So yes, the front of the car will loose 2.5" ground clearance. But, the front subframe won't be as low as the rear spring perches, and only an inch and a half or so lower than the exhaust.
Even truck lift kits lower the front end ground clearance by adding a cross member that loweres the front control arms (IFS setup. All half ton trucks made in the last 10+years)
Either way, with the 2+" of clearance gained with larger tires and the 3.75 inches gained with the lift, minus the 2.5" by lowering the subframe. It should still be 3.5-4" higher than the stock clearance.
Plus the ball joints won't be as stressed.
It's still gonna look cool as f*ck hahah
Old 09-07-2019, 08:18 PM   #122
Tskm2
Damm that really more work!! Do the same as alot of people in vw community and cut a half moon piece of steel/ notch just over the axle to clear the frame. That done alot of time in old vw mk1 to mk4
Old 09-09-2019, 10:06 AM   #123
myfirstyota
So, another update:
I picked up the metal to fabricate the sub frame spacers. The subframe attaches to the car in 6 spots. But unfortunately I only got enough to make the front 2 and middle 2 spacers, thinking I was gonna have to use something else for the rear 2. Turns out, I can use the same 2.5" square tubing to make the rear 2 spacers, but they just need to be a little longer.
So with the front 2 spacers cut, drilled and mocked up in place, and a jack under the back of the subframe jacked to the right height, I can now see where the subframe will sit. Problem here is the driver side cv shaft us just damn short. The shaft was pulled out from the trans side cup :(
Either gonna have to find a longer drive shaft or lower the engine.
Pros and cons
Longer driveshaft
Pro:
•probably can find one from another year/model pretty easily. Easily replaced if oem size is found
Con:
•doesn't change the angle of the cv shaft which will be significantly more than stock with the 3.75" of lift creating more wear on the joints
•may not find a suitable substitute/necessary custom shafts
Lowering engine/trans
Pro:
•restore or partally restore factory cv shaft angles
•direct replacement cv shafts
•lower center of gravity
Con:
•hoses, lines, wires, exhaust, shifter cables all must be kept in mind or extended where needed
•some sort of custom spacers between the engine/trans and it's mounts.
•will need quite a few specific metric bolts
I'm also having a bit of an issue finding the 2 metric bolts with the right thread pitches and length to fasten the 2 middle subframe spacers to the body.
When I find a good source for hardware I think lowering the engine is the best choice.
Thoughts?
Old 09-16-2019, 04:15 PM   #124
myfirstyota
Teaser
Holding itself up :)
Old 09-16-2019, 04:27 PM   #125
TiedBassDrummer
Drives: 08 Yaris 3dr
That looks awesome!
TiedBassDrummer is offline   Reply With Quote
Old 09-16-2019, 04:29 PM   #126
Leegamer
Leegamer's Avatar
My pants feel a little tight all of a sudden
Finally bought a lift CTScott DIY / Maintenance / Service 26 09-28-2010 09:09 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 08:35 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 08:42 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
