![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Okay, smart man that stated that 20wt is thicker than 30wt oil, **rust** is not what caused the OP excessive runout, heat must have warped the rotors...that's why there are machine minimum and discard specs, because less material = more heat, NOT more rust stains...big clue: if "HOT" was a good thing there wouldn't be vented rotors and drums.
#2 | |
That's what this thread has been about...assumptions/conclusions that rust overtook the rotor on the dealer's lot within the first 10 miles of life, and that's why the steering wheel shakes while applying the brakes.
![]() Besides, not everybody has the same concept of how hot "HOT" should be, so why risk damage to the rotors and pads, and possible brake fade when the dealer took care of it for free by fixing the runout problem... |
#4 | |
#5 | |
--getting them HOT does not damage them. --ok smartass, i should have said "heat is not what warps rotors” --i never said a single word about rust in this thread.
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
