Old 11-25-2009, 08:10 PM   #11
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
Last night, I was installing my new wheels, took the car for a test ride and when I got back I looked at it from behind very carefully. I might be wrong, but I swear I can tell the toe-in on the rear wheels. If you look carefully, along the tire walls, trying to align one edge with the opposite edge, looking along the vehicle, in a horizontal line, right above the center hub, you will see that the imaginary line hits the body somewhere in the front, it doesn't stay parallel to the centerline. And I noticed that with the axle mounted on the higher bolt. Imagine how much more toe-in you get on the lower bolt, since turning the axle forwards would probably increase the toe-in angle even more...
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 07:04 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
