![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
Last night, I was installing my new wheels, took the car for a test ride and when I got back I looked at it from behind very carefully. I might be wrong, but I swear I can tell the toe-in on the rear wheels. If you look carefully, along the tire walls, trying to align one edge with the opposite edge, looking along the vehicle, in a horizontal line, right above the center hub, you will see that the imaginary line hits the body somewhere in the front, it doesn't stay parallel to the centerline. And I noticed that with the axle mounted on the higher bolt. Imagine how much more toe-in you get on the lower bolt, since turning the axle forwards would probably increase the toe-in angle even more...
5% Tint Rear | Micro Image LED Ignition Light Kit |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
