Old 07-22-2013, 01:52 PM   #1
WestCoast
Drives: yaris
Good to know, and where is the Emergency Brake pin in my 2007 auto transmission yaris?
WestCoast is offline   Reply With Quote
Old 07-22-2013, 02:02 PM   #2
The yellow wire at the base of the ebrake lever or the yellow wire in pin 4C-2. The ebrake is typically not required for remote starters, except for with manual trans.
Old 07-22-2013, 05:26 PM   #3
WestCoast
Drives: yaris
Do my auto trans car still don't need the Door Trigger input for my remote start?
Old 07-22-2013, 06:05 PM   #4
Check the manual for your remote starter. Most do not require that, as they can be used with cars with manual locks.
Old 07-22-2013, 06:30 PM   #5
WestCoast
Drives: yaris
Where to output my (+) 12V Siren if i my car don't have the arm system?
Old 07-22-2013, 08:54 PM   #6
Unless you are adding a siren you won't need to connect that.
Old 07-23-2013, 02:22 AM   #7
WestCoast
Drives: yaris
My CM6200 said I need cut the green loop wire inside the brain module, but I can't find it, where is my green loop wire?
Old 07-23-2013, 06:00 AM   #8
It is inside of the remote starter, not a wire on the car.
Old 07-23-2013, 12:20 PM   #9
WestCoast
Drives: yaris
Thank you so much CTScott, I found it after I opened the CM6200 module.
Now, the wires have been connected, and I have tried to lock and unlock the door, works great.
When the car was running after I take off the key, I still can use remote start to shut it off. But the weird thing is, after I push the remote start button to start my car, the car just flash twice, then nothing happen, however the car will immediately start after I plug in the key without turn the key(just in the lock position even not in the ACCE or ON position).
Old 07-23-2013, 01:54 PM   #10
I have only installed a remote starter on a Yaris which has the engine immobilizer and therefor required the key bypass module. It sounds like even though yours does not have the immobilizer that the ECM wants to see the "unlock warning switch". It is a 2 pin connector on the ignition switch with a yellow and a white/black wire. As a quick test, just jump the yellow to the white/black by shoving a piece of wire in the back of the connector. If it remote starts with that jumped, then you will need to hook the yellow wire to the start #2 output of the remote starter.
Old 07-23-2013, 06:55 PM   #11
WestCoast
Drives: yaris
You are the amazing man CTScott, I never done this before, but every thing works great now.
Old 07-23-2013, 08:48 PM   #12
Nice! I am glad to hear it is done and working.
Old 11-08-2013, 04:16 PM   #13
eseibel67
eseibel67's Avatar
Drives: 2007 Yaris
I am trying to install Avital 4003 so I can use the existing factory remote lock signal as a trigger on an 07 Yaris Sedan.
On connector GD1, there is a brown wire on pin #5, and there is also a brown wire on pin #7. Turns out that the brown wire on pin #7 is the negative (-)lock pulse.
eseibel67 is offline   Reply With Quote
Old 11-10-2013, 06:23 PM   #14
eseibel67
eseibel67's Avatar
Drives: 2007 Yaris
I was wrong on post above. The negative pulse on connection above does not have enough juice to trip the remote starter signal.
Instead, I used the passenger unlock (+) pulse and inverted it with a relay to give the remote starter the (-) trigger signal it wants. This wire is located at connector 4H, the pink wire at pin #18.
Old 11-19-2013, 11:54 PM   #15
chadcox82
Drives: 2007 yaris
New to the forum but joined specifically because of this thread. I am thinking about installing a remote start on my girlfriends 2007 yaris with power locks but no factory keyless entry. Any suggestions for a simple, reliable yet relatively inexpensive remote start/keyless entry? I was looking at the VIPER 4105V, Are there any other systems you would suggest?
chadcox82 is offline   Reply With Quote
Old 11-20-2013, 06:29 AM   #16
That viper would be a good choice. I am still very happy with the UltraStart that I installed on my 09, back when I got it in October of 2008. I have not had a single issue with it in the 5 years that is has been on there and the range if awesome compared to Avital that I installed on my 08.
Old 12-18-2013, 08:54 PM   #17
JoeVR
Drives: 2008 Yaris
Hi Scott,
Thank you so much for this great page. I have a 2008 Yaris with power locks but no remote. I would really like to put a remote start and lock/unlock. I don't really need an alarm for it.
I was looking at the suggested models in your document from a few years ago, and I have found most of them are discontinued.
Can you suggest an updated model that would do remote start & lock/unlock that would work on my 2008 Yaris?
Thanks! I really appreciate any helpful suggestions you may provide.
JoeVR is offline   Reply With Quote
Old 12-18-2013, 09:07 PM   #18
Originally Posted by JoeVR View Post
Hi Scott,
I just picked up an Ultra Start 1272 XR Pro off ebay for the 2007 I am currently rebuilding for a buddy of mine. $47 is a great deal for it:
http://www.ebay.com/itm/261152420077...84.m1423.l2649
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
