In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
276165 miles and counting
and i still get between 620 and 650km per tank in the summer.
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Just hit 156k miles. Some squeaks and clunks here and there but still pretty good overall. Hoping to take the 1nz to at least 250k and then swap it.
![]() Drives: 2007 Yaris Join Date: Sep 2015
I am now at 175 and going. Hoping to make it to 300,000.
![]() ![]() Drives: 2010 3dr LB Join Date: Sep 2010
140,000 miles on 2010 2 dr manual hatchback. Synthetic 5000 mi oil and filter changes, air filter, cabin filter, tires, battery and plugs, serpentine belt and front brakes & rotors. just done. Funny thing is I work 2 days/week and live 1.25 miles from work. average between 36 and 42 mpg. Bill C
![]() Drives: 08 Yaris 3dr Join Date: Oct 2018
Bought my Yaris last year with just over 70k miles on it. Currently at 83k miles.
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
83<100
![]() Drives: 2007 THREE DOOR 5 SPEED Join Date: Aug 2009
Just made 250k. Drives just like it did when I bought new. People don’t believe me when I tell them I’ve only replaced the brake pads one time since I’ve owned it. I’m torn between my Yaris and my 2007 Ford Crown Victoria Police Interceptor as to which one is the greatest car ever built.
Gotta love it. |
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Good job, mark293! Hoping to drive my Yaris another 20 or so years. I'm at about 105,000 miles.
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
What's 366,000km worth? That's where my lift-mobile is at
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
My paint has done the same, but it happened very much all of a sudden.
I'm a hermit named Lee |
Drives: 2012 Toyota Yaris Sedan AT Join Date: Jan 2019
At 143000 miles on 2012 Yaris Sedan. Dealership recommends me to replace the throttle body and flush the brake lines. What are your thoughts? Also they said that I have a timing cover leakage, which when I dont see any obvious leak. Anyone with the same experience?
#12 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I change my brake fluid and flush my lines every 2 years/40,000 miles. You definitely notice a change in the colour of the fluid as you flush the new stuff through. Brake fluid absorbs moisture so it can cause corrosion in your brake system. I think they are having you on with "timing cover leakage" the timing covers are siliconed on at the factory. They are a bitch to get off and very unlikely to be leaking. You could have your front main seal leaking at the camshaft - that you should probably get fixed if it was the front main seal. Or you could have a coolant leak from the water pump. Mine leaks a little but i'm just keeping an eye on it at the moment because its just a drip. I just top up a few drops of coolant when i service the car.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#13 | |
![]() Drives: 2007 1.3L AWD (auto) Vitz 5 dr Join Date: Aug 2020
In my humble experience, any crud on the throttle body can be cured with a spray bottle chemical. I've watched a licensed mechanic here in Japan pull the air-box conduit, and then spray the daylights out of the throttle body while reving the engine on the under-hood linkage. It cleared up the rough idle and stalling, and the vehicle was good to go until it went to automotive heaven! This is a pretty normal thing! There is a SPECIFIC chemical spray for this application!! I see this stuff in the wholesale, pro-tool and supplies shop I go to here in Japan. FLUSHING BRAKE LINES This should be a standard part of maintenance. In Japan, it's done every two years as common practice! DOT-3 brake fluid is hydroscopic.This means it absorbs moisture. The hydraulic system has to vent, and thus it is open to atmosphere. It eventually collects H2O in your fluid. Water will settle in your brake lines and in your hydraulic brake cylinders and callipers. I think you are really pushing your luck at 143,000 miles / 230,000 Kms! Believe me — I've overhauled enough calliper bores, and either honed-out brake cylinders for new pistons and seals, or replaced them to know how they can rust and be ruined by contaminated brake fluid. You can work out the comparative cost of regularly flushing brake fluid as opposed to brake hydraulics overhauls. And I hate to think what might happen in the modern, pressure equalizer blocks — I never had to deal with those back in the days. In Japan, the seasonal high humidity can be intense (not unlike many states in the USA). Here in Japan, as a matter of common policy, we flush brake fluid ever two years as part of the preparation for the mandatory licensing inspection. My wife and I ran a Honda for 23 years. We had one brake cylinder bore go bad in the 21st year. And not because of rust. The piston seal was weak. (Of course we replaced both cylinders.) The fluid had been flushed every two years, and the front callipers never needed service except for fresh pads. If you are using DOT-4, it has a higher boiling point, but it is even MORE hydroscopic. So even more caution is advised. It must be great for track days, but I won't use it in my everyday transport. And in case it has escaped you, water in the brake fluid detracts from stopping power. TIMING COVER As for the timing cover — I dunno, but if it means what I think it means, if there is no oil weeping around it, I cannot see the reason for servicing it with a new gasket or sealant. Perhaps the dealer knows that the gasket/seal does begin to weep or leak at about the milage your car has gone. Hell — leave it until it does leak and just keep an eye on it when you do your regular check on the dipstick. (FWIW: I'm not a licensed mechanic, but years ago I serviced, repaired and overhauled stuff on motorcycles, cars and trucks for part of my living.) |
#14 |
![]() ![]() ![]() Drives: Charcoal 2012 Yaris SE 5 Speed Join Date: May 2016
Definitely wouldn’t see a reason to replace the throttle body. Brake fluid can get moisture in it, but if you don’t have issues with the car stopping I would decline that also.
It’s possible you could have a water pump failing, but I wouldn’t trust a dealer that said to replace a throttle body. I’ve personally never seen one fail on any car. |
#15 |
![]() ![]() ![]() Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
I am at 99,800 miles on my 2012, so I am fast approaching membership in this exclusive club. Do we get tee shirts or something? ;-)
#16 |
![]() Drives: 2007 Toyota Yaris 3dr Join Date: Apr 2020
231,000 miles today. 07 Yaris 3dr
#17 |
168,000 miles on my 2010 manual trans, 3 door hatchback. Had donut gasket and resonator replaced at 128,000, spark plugs, serpentine belt and front brakes/rotors done at 141,000. Full synthetic 5w-30 oil and filter every 5000 miles. Also changed the battery at 7 years because I did not want to push it and have it fail at an inopportune time. By far the best, lowest maintenance vehicle I have ever owned. Bill C
#18 |
166,000 Kms ... a tad over 103,000 miles. I've only had it since about 160,000 Kms.
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| 30,000 mile service: Dealership or non-dealership? | EstherK | DIY / Maintenance / Service | 1 | 11-12-2008 12:40 PM |
| 11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) | Jerkratt | NY / NJ/ CT / PA | 14 | 10-26-2008 05:51 PM |
| Japanese Mix Club Los Invitamos!!! | TunTun_yariS[PR] | Caribbean | 0 | 12-12-2006 12:03 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 06:55 PM |
