Old 09-27-2010, 07:22 AM   #12
Originally Posted by trini_per4mance View Post
I actually never took my Yaris back to the dealer to have them do anything on it. Remember I ran out of warranty only after 3 months of buying the the car. I only know everyone at the dealer b'cuz of my high miles everyone knows my car and always look out for me every time I visit the parts dept, from managers to salesmen to technicians. I'm the only person that works on my car. I actually bought a new relay myself and replaced it myself and the problem still exists.
What's the part number of the relay you have in there now (just to verify that it is the correct relay)?
From there I would check the following:
1. Ignition Switch - Remove the connector from the key switch and with the key off, check continuity between pin 5 (where the gray wire connects to) and pin 7 (where the black wire connects to). Then, move the key to each position and recheck. There should only be continuity between those two pins when the key is held in the start position.
2. While you have that connector off, on the harness side, measure the voltage between the gray wire and the black wire. It should read 12V. If it reads 0V, then there is a short in the wiring. If it reads more than zero, but less than one volt, then the automatic cranking circuit in the ECM is bad. This is the circuit that allows you to just bump the key and then the starter cranks by itself until the car starts. If that is the issue, you can do either of two things - Replace the ECM, or simply eliminate the "bump" starting (which you can do by cutting one wire in the under hood fuse box).
Sqweek while shifting (MANUAL) dallas DIY / Maintenance / Service 43 09-01-2010 03:57 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
