Old 07-05-2012, 05:58 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I believe that's about 10whp above stock... Not too shabby.
Originally Posted by tooter View Post
Does anyone have a dyno run of a completely stock Yaris for comparison?
*ahem*
http://www.yarisworld.com/forums/showthread.php?t=10320
Old 07-09-2012, 12:27 PM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Just got back from the dyno shop...
I think my excel sheet matches up pretty well. DATA!!!!!!!!!
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 07-09-2012, 12:33 PM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
But what does it mean?
Old 07-05-2012, 05:58 PM   #4
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Good results! I'm sure someone will chime in with stock dyno run, but unlikely we have one from a 2012 like yours. Your car has a different ECU than the 07-11 cars so it may net different results, certainly seems to like the few bolt-ons you've got so far!
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 07-05-2012, 07:57 PM   #5
tooter
play every day
tooter's Avatar
Here's a video of the 4th gear run...
http://www.youtube.com/watch?v=rYF6pvhn96U
Hey Jeff...
Your MI exhaust sounds really cool!
Old 07-05-2012, 08:45 PM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Damn...our cars really like exhaust then...i have less intake and more exhaust and have 7-8more whp.
I wonder how much a long header could really produce
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-05-2012, 08:53 PM   #7
tooter
play every day
tooter's Avatar
For comparison, what intake and exhaust are you running? The bottleneck on mine is the stock mid tube.
Old 07-06-2012, 03:36 AM   #8
ljming99
Drives: Yaris '06
If you plan to stay NA, start with the header...the stock "collector"(not sure if correct term) where the 4 pipes of the header joins together is very very small and that restricts quite abit of power
ljming99 is offline   Reply With Quote
Old 07-06-2012, 12:05 PM   #9
tooter
play every day
tooter's Avatar
Yes, that's where I started, too.
Old 07-06-2012, 05:53 AM   #10
malibuguy
Obsessed with 1.5L
Stock air box...removed carbon filter and im running an Apex-i drop in replacement filter. I made a full custom 2" mandrelbent exhaust. I also have amsoil synthetic trans and engine oil. Also i have a weaponr header too
-96 Tercel 4dr
Old 07-06-2012, 12:03 PM   #11
tooter
play every day
tooter's Avatar
Ah, there's where you got those extra horses.
Since I have a header and an axleback, that bigest gain is found in the midpipe.
Old 07-06-2012, 12:19 PM   #12
BEEF
BEEF's Avatar
those numbers are interesting. I was hoping for around 105 or so. I am actually going to be going 2" from the resonator back with mine. there is a short section that is actually oval shaped that seems really restrictive.
I am really looking forward to seeing what your intake manifold does for you. any ETA on when that is going to be finished?
Old 07-06-2012, 12:49 PM   #13
tooter
play every day
tooter's Avatar
I was hoping for 95 horsepower.
After, all I've only done just a few simple peripheral mods.
The CNC guys were concurrently working on multiple machining deadlines so mine had been getting pushed back. The other projects are finished now so they're working on mine. Just talked with them this morning and they're modelling the face plate design to accept the stock intake manifold gasket. I want this to be something that everything fits properly so I can simply bolt it on and run it.
I showed the manifold to Harry, the guy who runs the dyno shop, and he told me that while the manifold should show some power gains above 4,000 it will be at the sacrifice of power down in the 2,000 to 3,000 rpm range. He said it was because the larger volume of the runners will slow down the velocity of the air at low rpms. The question is how much bottom end will be lost... I'll find that out on the next dynos.
Old 07-06-2012, 01:02 PM   #14
BEEF
BEEF's Avatar
it would be nice if you had a data file of the dyno and you could literally see the delta (positive or negative) in maybe 100 rpm steps. I know that it may be too late for that. maybe you could overlay the two dyno runs if your dyno guy keeps the files (I assume he would)
I like the progress you are making. it may be advantageous for you to go to a muffler shop and get them to replace that run of 1.75" pipe with 2"...obviously not until you get the intake manifold experiment done.
when you get the manifold done, we definitely need some pics of the final product also.
Old 07-06-2012, 03:08 PM   #15
tooter
play every day
tooter's Avatar
You mean like this?
Dynojet Research Inc.
Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_001.drf
Run Title: 2012 Toyota Yaris Greg Mamishian
Run Notes: Weapon R Intake
BLOX Velocity Stack Air Filter
Weapon R 4-2-1 Header
Micro Image MagnaFlow Exhaust
Run Date: 7/5/2012 12:07:06 PM
RunFile_001.drf: 78.46 °F 29.19 in-Hg Humidity: 45 % SAE: 1.02 Average Gear Ratio: 52.53
s RPM x1000 hp ft-lbs Air/Fuel
0.69 2.10 34.69 86.77 14.89
1.47 2.20 37.21 88.84 13.05
2.25 2.30 38.89 88.80 12.36
3.00 2.40 41.30 90.38 12.36
3.76 2.50 43.35 91.07 12.42
4.51 2.60 44.87 90.65 12.30
5.28 2.70 45.91 89.31 12.15
6.05 2.80 47.64 89.36 11.98
6.82 2.90 49.39 89.45 11.70
7.60 3.00 50.66 88.69 11.90
8.38 3.10 52.12 88.31 11.79
9.15 3.20 54.52 89.49 11.93
9.90 3.30 57.61 91.69 12.35
10.65 3.40 60.03 92.73 12.35
11.39 3.50 62.20 93.34 12.18
12.12 3.60 65.50 95.56 11.98
12.84 3.70 66.59 94.53 11.95
13.57 3.80 68.98 95.34 12.08
14.29 3.90 72.28 97.33 12.39
14.99 4.00 74.58 97.92 12.29
15.70 4.10 76.66 98.20 12.08
16.41 4.20 77.84 97.33 12.11
17.11 4.30 79.09 96.60 12.11
17.85 4.40 81.29 97.03 12.16
18.57 4.50 82.25 96.00 12.30
19.30 4.60 84.32 96.27 12.21
20.01 4.70 86.01 96.12 12.29
20.76 4.80 87.75 96.02 12.41
21.49 4.90 89.12 95.53 12.40
22.23 5.00 91.66 96.28 12.49
22.96 5.10 93.48 96.27 12.66
23.70 5.20 95.13 96.08 12.91
24.43 5.30 95.75 94.88 13.22
25.18 5.40 97.30 94.64 13.54
25.97 5.50 98.27 93.84 13.82
26.72 5.60 98.02 91.93 14.01
27.51 5.70 98.19 90.47 14.23
28.33 5.80 97.09 87.92 14.36
N/A 5.90 N/A N/A N/A
29.99 6.00 97.60 85.47 14.62
MAX: 29.99 6.00 98.27 98.20 14.89
MIN: 0.69 2.10 34.69 85.47 11.70
Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_002.drf
Run Date: 7/5/2012 12:17:31 PM
RunFile_002.drf: 79.85 °F 29.19 in-Hg Humidity: 43 % SAE: 1.02 Average Gear Ratio: 52.49
0.69 1.80 26.43 77.12 14.89
1.57 1.90 28.78 79.55 10.00
2.38 2.00 32.66 85.78 10.31
3.17 2.10 35.21 88.07 11.72
3.93 2.20 37.94 90.58 11.88
4.69 2.30 39.27 89.68 11.91
5.44 2.40 41.93 91.76 12.00
6.19 2.50 44.02 92.48 12.04
6.93 2.60 45.80 92.53 11.71
7.68 2.70 47.11 91.64 11.69
8.43 2.80 48.68 91.31 11.82
9.18 2.90 50.37 91.23 11.74
9.95 3.00 51.69 90.49 11.79
10.71 3.10 53.59 90.80 11.82
11.46 3.20 55.84 91.65 11.91
12.20 3.30 58.45 93.02 12.33
12.98 3.40 60.89 94.05 12.33
13.40 3.50 62.50 94.13 12.17
14.38 3.60 66.31 96.74 11.95
15.10 3.70 68.15 96.74 12.06
15.88 3.80 70.26 97.11 12.16
16.51 3.90 73.62 99.15 12.24
17.20 4.00 76.60 100.57 12.35
17.90 4.10 77.95 99.86 12.21
18.60 4.20 78.93 98.70 12.12
19.29 4.30 80.56 98.39 12.16
20.02 4.40 82.43 98.39 12.24
20.71 4.50 83.86 97.87 12.29
21.44 4.60 86.06 98.26 12.20
22.16 4.70 87.22 97.46 12.22
22.88 4.80 89.28 97.69 12.30
23.60 4.90 90.73 97.25 12.35
24.33 5.00 93.11 97.80 12.31
25.06 5.10 94.49 97.31 12.25
25.78 5.20 96.40 97.37 12.33
26.51 5.30 97.90 97.02 12.40
27.25 5.40 99.20 96.48 12.61
28.00 5.50 99.22 94.75 12.92
28.77 5.60 99.45 93.27 13.29
29.57 5.70 98.75 90.99 13.62
30.37 5.80 99.30 89.92 13.89
31.19 5.90 98.67 87.83 14.11
32.05 6.00 97.61 85.44 14.29
MAX: 32.05 6.00 99.45 100.57 14.89
MIN: 0.69 1.80 26.43 77.12 10.00
Run Name: C:\DynoRuns\Toyota\2012 Toyota Yaris Greg Mamishian\RunFile_003.drf
Run Date: 7/5/2012 12:22:20 PM
RunFile_003.drf: 80.12 °F 29.20 in-Hg Humidity: 41 % SAE: 1.02 Average Gear Ratio: 52.46
0.75 2.50 44.23 92.92 12.69
1.49 2.60 45.99 92.90 12.16
2.24 2.70 47.27 91.96 12.03
2.99 2.80 48.95 91.82 12.04
3.75 2.90 50.38 91.24 12.06
4.50 3.00 51.93 90.91 12.04
5.27 3.10 53.56 90.74 11.95
6.02 3.20 55.65 91.34 12.08
6.77 3.30 58.54 93.17 12.54
7.50 3.40 61.18 94.50 12.52
8.22 3.50 63.54 95.35 12.25
8.94 3.60 66.56 97.11 12.02
9.65 3.70 68.05 96.60 12.07
10.37 3.80 70.09 96.87 12.37
11.07 3.90 73.58 99.09 12.48
11.76 4.00 76.68 100.68 12.56
12.45 4.10 78.78 100.92 12.32
13.15 4.20 79.58 99.52 12.33
13.83 4.30 81.10 99.05 12.32
14.56 4.40 83.05 99.13 12.35
15.27 4.50 84.57 98.71 12.26
15.98 4.60 86.14 98.35 12.18
16.69 4.70 87.84 98.16 12.29
17.41 4.80 89.39 97.81 12.31
18.14 4.90 90.94 97.47 12.22
18.86 5.00 92.20 96.85 12.13
19.59 5.10 94.17 96.97 12.15
20.32 5.20 96.37 97.34 12.17
21.05 5.30 97.80 96.92 11.96
21.79 5.40 98.64 95.94 11.96
22.55 5.50 99.23 94.76 11.93
23.32 5.60 99.72 93.53 11.97
24.11 5.70 98.34 90.61 11.89
24.92 5.80 98.45 89.15 11.78
25.75 5.90 98.30 87.51 11.76
26.60 6.00 98.02 85.80 11.94
MAX: 26.60 6.00 99.72 100.92 12.69
MIN: 0.75 2.50 44.23 85.80 11.76
This is where I'm still at...
With the short ram completed and the baseline dyno done, everything is now waiting on the CNC guys to punch out the head flange and throttle body adapter. Then I go the welder to get the flange put on. Then I get the whole thing sandblasted.
Old 07-06-2012, 04:07 PM   #16
FWIW, I ran 106whp/107wtq with intake, 2.25" crush bent resonator-axle section and a Megan axleback .....no header
Dyno's vary and can really only be relied on comparisons to personal runs....or if a stock yaris runs on the same day. That said, 100whp with the wimpy stock 1.75" midpipe makes sense...
Old 07-06-2012, 04:34 PM   #17
tooter
play every day
tooter's Avatar
I understand... and that's why I'm not concerned with the absolute output of any one dyno run as far as the exhaust is concerned. Right now I'm focused on the intake manifold and in the relative difference between two dyno runs with the manifold as the only difference.
Maybe later on I'll post another thread on "tooter's exhaust adventure". But not now. Just one project at a time.
Old 07-06-2012, 03:53 PM   #18
BEEF
BEEF's Avatar
that's beautiful. excel can be your friend. that will show you the advantages and disadvantages to your intake manifold.
you have quite the project going here. now I am chompin at the bit for more.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
