Definitely sounds like I should be considering a catch can myself.
You must be itching to try out those new tires.
Losing more weight - battery
My old flooded lead acid battery from CT went to crap so I decided on a pricier but more reliable and safer (non spillable since it is now in the cabin) AGM battery. This thing is a beats, smaller in diuameter than the group 36 it replaced but has 655 CCA's and 50 Ah (100 reserve). However, in the rush to grab a new battery I didn't really think of the weight. The AGM battery although smaller, is just as heavy as the old one and probably weighs around 35-45lbs!
I ended up ordering an AGM motorcycle battery online which weighs a claimed 11lbs (probably closer to 12). It is rated at 270 CCA and has 18Ah (36 reserve). This cranks the car barely noticeably slower in 0 degree C temps but has no problem The issue with small batteries is their lack of reserve capacity. This can lead to the battery draining down after a couple days, especially in the cold. I installed it fully charged reading just over 13V and after about 24 hours it was at 12.54V which is about 80% charged. It turned over the engine this morning in -10C temps albeit a bit slower than it typically does. I bought a small trickle charger/maintainer that I will hook up in the winter if I am going to have the car sit longer than 2 nights. I can leave the maintainer in my car and just hook up an extension cord as needed. These batteries typically die an early life because people drain them and then jump them. Anytime a battery gets fully drained you can say good bye to it's useful life. AGM's can tolerate lower discharge amounts, but they srtill are not immune to this happening. Best practice is to keep a charger on it if it won't be used for a while. These batteries are also sensitive to heat but this won't be a problem as I have mine in my cabin. All in all I just lost about 25-35lbs out of my car for very little money ($50 USD shipped with taxes) I had to flip the battery tie down bracket so I had usable threads on the rods but it is holding very tightly and won't budge. I never needed any battery post adaptors as I just unbolted my oem post terminals from my ground and pwer wires and bolted those directly to the motorcycle style terminals with a washer. Simple and effective. ![]() ![]() ![]() ![]() up next is my Vibe radiator install...easter long weekend is looking like a decent time to do it
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
It's so cute.
I'm a hermit named Lee |
3 Yaris and counting..
You need a smaller battery box now!
Swapped out my 0w30 Mobil 1 for some Quaker State full syn 0w20. I will post up any difference I see in oil pressure or temps. Based on 540Rat's testing on his blog I opted for this oil due to its very impressive psi rating. The only other oil better than it was Amsoil and I picked up QSUD for $31 for 5L on sale and my Amsoil price of 0w20 signature is much higher than that.
I also am trying out a larger filter this time around, much higher capacity, brings the 2zr from 4.4 L to some where just shy of 5L so probably an extra 200-400ml capacity. The filter is currently a Fram Ultra Synthetic and is spec'd on many of Toyota's v6 engines as well as a 2002 2zz Celica GTS. The only difference between them is the larger filter specs a slightly lower bypass valve PSI of 12 vs 14PSI for the regular filter. The should be a moot issue for me. Regular oem direct replacement ![]() larger capacity filter ![]() the larger capacity is larger and barely clears the engine block. It leaves about a 1/4" between the filter housing and block. ***take note - keeping the throttle pedal fully depressed when starting the 2zr does not put it into clear flood mode and cut off fuel. It leads to your bouncing off the rev limited at start up*** learn from my mistake...good thing I fully fill/prime the oil filter during install. All that is left is to make a new rear brake line due to rust and replace the front rubber lines and bleed the system. Then off to the track!
#6 | |
![]() I drained my Redline MT-85 after about 6k km on it throughout the winter. It shifted very well in the deep cold of our winter but I noticed the shifting degraded slightly as the temps stayed above 0*C. I always planned to run MT-90 during the track season due to higher temps. When I drained the MT-85 I noticed what I thought was an alarming amount of gold specs suspended throughout the trans fluid. No large chunks, all specs and the magnet on my Mishimoto plug was very clean. My guess is the synchros, but I only ever have a 3rd gear synchro issue when I do really quick shifts, or when I'm at the track under hard cornering. I'll see how the MT-90 fares, but I seriously contemplating trying to find a GL-4 75w90 (or 80w90 at the very least) conventional trans fluid. I'll just change it out more often due to high track temps, but I'm starting to question the MT-90 in out old Yaris manual transmissions. I'm trying to balance good shifting with a clutch type diff all housed in the same box. The MT-90 did a great job for this and is easy for me to find. I'll post any updates as I figure this out. It's possible that the fluid had nothing to do with this but I'm going to keep an eye on it. Tomorrow I'm going to plug away at the last thing I need to do which is replace the 4 rubber brake lines. The rears are seized so it looks like I'll be replacing the whole main lines that run to the rear with some NiCop lines I'll be bending myself. That should be a learning curve
Soft brake lines in the front replaced and hard lines in the rear replaced with NiCopp line. I have rear soft lines but they are seized to the line that travels under the car up to the front of the car. I didn't have time to use some heat and vice grips to try and free it up so I just soaked it in penetrating fluid. My line wrench was starting to slip on the nut and it has a lot of play on it so I just stopped.
Bending my own lines went fairly well but it was a learning experience for sure. NiCopp is crazy easy to use as it is very flexible and I ended up making most of the bends with my hands. I have a line bender but the bends are not a super tight radius like the OE lines are so my hands did a better job. I practised about 10 times making double flares the day before and it went ok. The generic tool is fine for a DIY'er but you have to be super careful that it is on the line perfectly straight or you have to re do it. NiCopp never rusts like the original OE lines so it give you some piece of mine. Pro tip: remove the OE line from the car and then put it on a bench and bend your new line following the old line. Do not try and use a coat hanger that you bent to try and copy it. This may work for simple bent lines but the rears in the Yaris have so odd shape bends and angles and it definitely did not work nearly as fast as just following the original line. Pro tip #2: Place plastic wrap or half a ziplock bag under the brake reservoir cap. This blocks off the vent in the cap and creates negative pressure as brake fluid drips out of your open lines. This really slow down the leaking of the line quite a bit. They still drip but much much slower so you are not having to constantly fill up the reservoir to avoid bench bleeding your M/C. I finally got to use my new Toyota specific properly sealing reservoir cap that attaches to my pressure bleeder. Seals perfectly fine and held 20psi with no leaks. Was able to completely flush my fluid in all 4 brake and my slave cylinder in under 15 mins by myself - seriously this tool in unreal with the proper cap. One of the original rear lines - it started to rust on the metal that is near the nut as it isn't coated in poly ![]() Line #1 ![]() Line #2 ![]() ![]() ![]() ![]() ![]() I also made a proper bracket for all of my power cables that attach to my main power line in the engine bay. Previous to this the fusible link and all the wires were sort of just hovering in space "supported" by the wires themselves. As the temps warmed up the cable became softer and it started drooping. I didn't want the wires to becomes damaged due to bumps and track driving. The bracket was a simple piece of aluminium and I used a preexisting threaded hole that is on the top of the trans mount meant for the factory battery tray. Because you cannot directly attach the power wires to a piece of metal touching the grounded chassis, I had previously ordered an insulated threaded post from Amazon. I used self tapping screws to mount the insulated post the the bracket and then mounted the whole fusible link to the insulated post. I wanted to keep the main fuses just in case I do an electrical no no and it will save me from a blown ECU and other things. It is good to have that thing still around. ![]()
Continued on my quest this weekend to have my car fully track ready. Fab'd up a small bracket to fix my now completely unsupported DC Sports CAI. The CAI is meant for a Scion xD and it will work in our Yaris' however it forces the intake filter against the left headlight. This leads to the head light point upwards (can be adjusted so you are not blinding others) as well as puts stress on the rubber mounting bracket that comes with the intake.
My bracket ended up breaking at the rubber damper a few months ago and was only supported by the silicone coupling at the throttle body. This needed to be dealt with properly as the stress and bumps at the track could lead to a vacuum leak. I took some flat metal stock I previously had lying around from my radiator install and bent a z shaped bracket to replace the broken one. I tapped the bracket on the end closest to the headlight so I didn't have to install as nut as well. Cheap and dirty but it works very well and the intake now has no movement at all. I also was able to reposition the intake so the filter not is not putting pressure against the headlight housing and they are completely free of one another. I had to run the bumper wiring loom above the intake a opposed to its stock location running below it but this was to avoid contact and potential rubbing away of the insulation on the wiring harness. ![]() ![]() I will be getting a corner balance and alignment done and then everything is a go!
Haha, very cool and creative. One thing I've noticed is that virtually every adaptation/mod I have done related to my turbo build has been do-able because of the way the Yaris is designed. I always seem to have just enough space (with slight modifications), always have some convenient place to anchor stuff too etc. I can definitely say that I got lucky a few times.
Do you have any concerns about vibrations causing cracking in the plastic headlight body? The headlights do seem quite robust, however. I do like where your filter is placed. I'd have mine there too if it weren't already occupied by the charge piping.
#11 | |
The intake and filter is no longer touching the headlight housing since I installed my bracket. There should be any contact even with bumps so there should be no issue of cracking. The original bracket supplied by DC is rubber dampened but my bracket is not, potentially my bracket could crack but it seems very stable and the intake is not overly heavy so it should be fine
#12 | |
I didn't realize that your mount was not on the headlight housing. Sounds like you've got a great solution there.
#13 | |
The intake mounts to a bolt hole with a bolt that grounds the headlight harness just in front of the headlight. That is where the original DC intake mount bolted to
#14 | |
I'm guessing that they are DI if they are suffering the intake coking. And, yes, they''re pretty cramped in the engine bay from what I've seen. Sounds like your intake is 'track-ready' now. We plan to be in Toronto again this summer, though haven't set hard dates. Maybe it will correspond with one of your track days. I bet my son would love to see that, haha.
Decided to pull my coil packs today and inspect for oil leakage and everything came up clean. I have about 50,000km on the engine since I installed it and I changed the valve cover gasket before I put it in.
![]() ![]() ![]() ![]() The reason I decided to look into this is that my '05 Vibe developed a consistent misfire in cylinder 3. I figured it was a bad coil but when I went to pull the coil to swap it to another cylinder to see if the misfire moved, I realized the spark plug hole of cylinder 3 was full of oil almost above the spark plug! The other spark plug holes has oil in them but not nearly as bad. I had replaced the valve cover gasket when we bought the car used and it only has about 55,000km on the gasket. It was a brand name gasket not some ebay cheapie. I put in a new valve cover gasket and replace the plugs as they were badly fouled with white crud. I fired up the engine and it was misfiring this time in cylinder 1. I replace the coil and it now runs fine. I am blown away that a quality valve cover gasket went bad at only 55,000km. I'm not sure if it is a coincidence and the coil went bad around the same time the valve cover gasket went or if the bad gasket led to the coil going bad. Either way I would check your spark plug hole periodically, luckily this happened one week before heading on a long family trip to the cottage and I was able to diagnose and fix it before. The 2zr has a different design of gasket around the spark plug hole and it should last longer but the 1nz has the same design as the 1zz engine in my Vibe. The gaskwet typically fails externally which shows up as an oil staining the top of the head, but it can fail internally and be fine externally, this may save you a bad day.
Great tip! You're learning so much about these engines/drivetrains etc that you should publish your own "How To" maintenance/repair manual.
Lol ya no kidding! I just try to post up as much info as I can so others can learn from my experiences. Always learning new things on these cars
I have booked a corner balance and alignment for the first week in June. I won't be heading to the track until then as I want everything well balanced for I start pushing the car. I am planning on going with 1/8th" total toe out in the rear and the front. This allows the car to have some sharp turn in in the front but yet the rear will still kick out a bit which aids in cornering.
Something I've always been amazed by is when you are watching pro drivers in a chicane and they aren't even steering the car as the rear end comes around just enough to point the car where it needs to go. This alignment will help with that with the negative being the wear on the inside of the tires. This is how I had my car set up last season and the turn in was spot on and I was able to control the rear end with changing the dampening on my coilovers. I ruined the alignment slightly when I had to replace worn ball joints so it needs to be re done. I have also removed a handful of weight form the car so a corner balance is in order. I am curious as to how much my car weighs now, I'd be surprised if it wasn't around 100lbs lighter. I'll post the results here once I get it done. I also want to build a radiator duct shroud before my first track day as the air can go underneath the car as it sits right now once it enters the lower grill. I plan to riv nut it into place on the lower rad support so it can be removed when needed
| Need 07 Sedan Tail Light wiring info ASAP | atebit | General Yaris / Vitz Discussion | 3 | 09-07-2013 06:48 PM |
| Swap sedan tach into liftback | GrassrootsMS | DIY / Maintenance / Service | 17 | 09-26-2007 09:45 AM |
| thinking about buying the sedan. is it worth the extra money for the s(optB) version? | friedbbq | General Yaris / Vitz Discussion | 14 | 05-20-2006 12:53 PM |
