Solution found! Took 5 mins to fix it this morning when I hooked my battery back up after charging. I'll post the solution and pictures later today when I get a chance, but long story short, the headlamp fuses are constant 12v, not ignition 12v like the MAF should have.
I am now down to 20mA of parasitic draw which is well within the normal and should leave your battery fresh (assuming it's a good battery)
#2 | |
Yes to the EFI fuse, it is one of the only ignition switches 12v sources. I moved some connectors around to make it easier to run the fuse tap wire
3 Yaris and counting..
I guess I may have to take a look at mine now. I just populated an empty fuse slot with the proper connector. But with all busses being powered all the time, i can inly imagine ill also have an issue but have yet to see it. Im Also not driving the car so no reason why i would have seen it yet.
#5 | |
Keep in mind your draw will only be 110-140 mA, not 300mA like mine was since you dont have a faulty keyless entry. Still enough to slowly drain a battery but not as quickly. Either way, having constant power to the MAF can't be helping its longevity with its temp sensor
I was thinking that when I did the swap. "Its ok to have the maf powered all the time?" I came to the conclusion everything else on the buss was.... must be fine.
#7 | |
Yes, once I'm on my laptop in an hour I'll post my imgur pics up. You current set up will be long enough as the fuse is actually a bit closer to the wiring loom than the lightbulb fuse
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 2ZR MAF sensor connector info | CrankyOldMan | Yaris TS Talk | 0 | 12-10-2018 03:05 PM |
| Dropping the tans in a 2zr swapped Vios | tmontague | Performance Modifications | 2 | 04-29-2017 07:29 PM |
