Old 03-20-2019, 01:16 PM   #1
Tskm2
Drives: Yaris hatchback 06
http://www.subcompactculture.com/201...yaris.html?m=1
Tskm2 is offline   Reply With Quote
Old 03-20-2019, 01:17 PM   #2
Tskm2
1.5in lift
Old 03-20-2019, 01:23 PM   #3
Maritime
Drives: 2008 yaris 5dr hatch
Originally Posted by Tskm2 View Post
That's not the same car. that's the overlander. We all know that one already and the 1.5 lift is what I am doing after reading that article. The other one Yarmaty posted has Cali plates and different wheels and appears to have little to no lift on it.
Maritime is offline   Reply With Quote
Old 03-20-2019, 07:39 PM   #4
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
I was thinking of doing a front suspension lift similar to what CTScott did with Crashy, just maybe utilizing plates with three holes in them so it’s not quite 4”. Then maybe just some slightly bigger springs in the rear, maybe from an xD to level it out.
Maritime, your don’t think the Cali Yaris has any lift on it all all? You think it’s all tire lift and he just trimmed fenders?
Hot Rhonda
- Bayou Blue
- Cosmo Racing Short Shifter
- Kenwood Single DIN Aftermarket Headunit
- Rockford Fosgate Punch 6.5” Speakers
“the dents make her handle better.”
YarMatey is offline   Reply With Quote
Old 03-20-2019, 10:45 PM   #5
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I also thought of this, but didn't want to regret not going high enough!! Hahah I'm aiming for 3&3/4" in the front with the 4 hole setup. I think that, plus whatever I can fit in tires, will make this car a monster. It already climbs snowbanks like an atv.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 03-20-2019, 07:47 PM   #6
Maritime
When I look at the rear axle it looks like its in the same place as stock. He has major offset and trimmed arches so tire lift is all of the height at least to me.
Sent from my moto e5 play using Tapatalk
Old 03-20-2019, 08:10 PM   #7
Tskm2
The second picture rear coil look bit to compressed maybe from the top spring...1.5in give the chance to put tire 3in diameter bigger and keep stock wheelgap at 27in tire that pretty nice
Old 03-20-2019, 09:11 PM   #8
YarMatey
Yeah it’s very possible that it’s all tire lift I guess. I’m wondering if a guy could get away with less drastic of a wheel offset, without lift, and without rubbing issues up front.
Myfirstyota, do you by chance have any pictures of the front end lift plates that you fabricated up?
Hot Rhonda
- Bayou Blue
Old 03-20-2019, 10:24 PM   #9
myfirstyota
I actually just cut them today. I have yet to drill the 16 holes in the 4, 1/4" thick plates its gonna take to make these work. And there's still another 6 spacer plates with 2 holes each that need to be fabricated. However the spacer plates will be thinner metal so should be easier to drill.
I plan on fabricating the other rear spring spacer this weekend. If all goes well there, we could have a rear lift in by Sunday
Old 03-20-2019, 10:36 PM   #10
myfirstyota
I think the rear axle on the black California yaris pictured looks pushed down. If you look at the center of the wheel in comparison to the bottom of the body, it looks in line. Mine kinda sits above the bottom of the car, and I have way stiffer xd springs in mine.
Can anyone with stock springs with a hatchback chime in? Where does the center of your rear hub sit in relation to the bottom of the car?
Old 03-20-2019, 11:01 PM   #11
YarMatey
I have a 5dr hatch on stock springs and the rear hub is in line with the bottom of the rear bumper and maybe a couple inches above the bottom of the car body (between the front and rear wheels).
I mean I suppose I could always make a four hole set and if it’s too high just cut some off the end of each bracket and end up with a three hole set. Did you get a noticeable lift in the rear with just the xD springs prior to fabricating your spring mount towers?
Hot Rhonda
- Bayou Blue
Old 03-20-2019, 11:42 PM   #12
YarMatey
Also, came across this on Instagram too. Guys brother made a killer custom roof rack for his Yaris and lifted it with what he said were 4Runner coils in the rear and strut mount extenders. Makes me wonder if just throwing some 4Runner springs back there is what he’s talking about?
Hot Rhonda
- Bayou Blue
Old 03-21-2019, 03:27 PM   #13
myfirstyota
I can't help but think that would ride quite rough..
Old 03-21-2019, 08:51 AM   #14
myfirstyota
The lift on xd springs was noticible. When I lowered the car back onto the wheels it barely squatted. I'd say about an inch of lift. Although I went from lowering springs to the xd springs so I can't give an exact amount of lift.
Old 03-21-2019, 03:30 PM   #15
Maritime
Yeah, 4 runners weigh a shit ton more than a yaris. Spring rate must be 4X or more. It would be like having no springs at all.
Old 03-21-2019, 07:52 PM   #16
YarMatey
Yeah very fair points. I guess maybe a cruise to the junkyard with a tape measure or calipers might be in order to find some similar OD ones.
Definitely stoked to see some pictures of your Yaris Myfirstyota once you get all your fab work done and installed!!
Hot Rhonda
- Bayou Blue
Old 03-21-2019, 10:25 PM   #17
myfirstyota
Still aiming for the rears to be complete this weekend! Pics soon!
Old 03-22-2019, 08:35 AM   #18
Maritime
Yay, good luck. I also hope to get my whole lift in. I have to start with the rears and check fitment of the unbranded lifts I bought off amazon. May need to mod those, if they need modding, it won't get done, if they fit. I'll have her all lifted this weekend. I only have about a 2-3 hour window of time and being my DD I need to get it all done in that time or wait.
Finally bought a lift CTScott DIY / Maintenance / Service 26 09-28-2010 10:09 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 09:35 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 09:42 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 03:33 PM
