Old 03-27-2019, 02:29 PM   #1
Maritime
Drives: 2008 yaris 5dr hatch
Originally Posted by myfirstyota View Post
We still gotta figure out the fender flare situation lol
I found some that are flexible in shape. Like a roll you trim off what you need and attach it to the fender and it conforms to the shape. I'll try and find the link. not sure I saved it.
Maritime is offline   Reply With Quote
Old 03-27-2019, 02:50 PM   #2
Maritime
Did a mock up, I scaled the 2 in the pic until the small was the same as the old tire so this is close to what the new tires will be like!
Old 03-27-2019, 02:57 PM   #3
Maritime
These are the flare I was thinking may be good as they follow however you cut.
https://www.amazon.ca/dp/B0794BXHSQ/...4-339eef22020c
Old 03-27-2019, 03:00 PM   #4
myfirstyota
3 Yaris and counting..
Oh wow... I hope that's not the case!
I'd be worried about structural damage cutting that much!
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 04-02-2019, 12:51 PM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
What a beast, she'll be! Pumped to see the final effect.
Old 03-27-2019, 03:05 PM   #6
Maritime
Paint isnt perfect fir sure. I bet it wont be that drastic
Old 03-27-2019, 03:28 PM   #7
YarMatey
Drives: 2008 Toyota Yaris 5dr Liftback
You guys will be able to get away with much more rear wheel cutting than us four door hatch drivers. We’d have to end up cutting into the doors haha.
I know that in place of all terrains some Subaru guys run chunky winter tires such as the Firestone Winterforces. They have a relatively aggressive look to them and would be available in sizes smaller than the 27” grabbers.
Hot Rhonda
- Bayou Blue
- Cosmo Racing Short Shifter
- Kenwood Single DIN Aftermarket Headunit
- Rockford Fosgate Punch 6.5” Speakers
“the dents make her handle better.”
YarMatey is offline   Reply With Quote
Old 03-27-2019, 03:38 PM   #8
Maritime
I'm a 4 door LOL. I've owned grabbers and like the low noise but the AT tread, a lot of the beefy winters are noisey as hell and soft so in summer they melt off the car.
Old 04-02-2019, 01:34 PM   #9
myfirstyota
Still lots of steel to grind out on the front lift. It'll happen soon lol
Old 04-20-2019, 07:29 PM   #10
Tskm2
Drives: Yaris hatchback 06
Update?
Tskm2 is offline   Reply With Quote
Old 04-20-2019, 11:43 PM   #11
myfirstyota
The rear spacers are holding beautifully. Probably 7-9000 km and everything seems great.
Im about half way done the front. I had to buy an electric die grinder. I settled on a rotozip. Was about half the price of an electric die grinder with variable speed. Its basically a dremel but 4 times the size and power. Hopefully can handle the job unlike the mastercraft rotory tool. Im hoping in the next 2 weeks ill be ready to install the front lift. Ive been working out of town and thats been slowing progress down.
Old 04-26-2019, 02:25 PM   #12
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Stock springs. Tokico reds. BFG All Terrains. 0195/75-14
Just to give you guys an idea to the clearance around the tire
Old 04-26-2019, 07:29 PM   #13
Maritime
Hey, how much to ship to 04730 ME? Id be interested.
Sent from my moto e5 play using Tapatalk
Old 04-30-2019, 02:49 PM   #14
justjesus
justjesus's Avatar
Got two quotes. Not looking good.
First one was $83.49 each (about 334 for 4)
Second one was $354 total for 4.
I do have a 5th tire, new as well, so that's additional shipping charge
Yes, that was just the tires. The weight of the wheels was not included in those quotes! And those are just the shipping costs.
At this time, it might be better/ cost effective to get some new tires. Maybe those 27s and make them work with a small lift.
Old 04-29-2019, 04:26 PM   #15
myfirstyota
Updates! Post #2
Old 04-29-2019, 04:50 PM   #16
Maritime
Those look good. I thought about something like that but didn't need that much height so went from the top. May re-think it after I see yours installed.
Old 04-29-2019, 07:37 PM   #17
myfirstyota
Thanks! I'm not a machinist by any means. And it isn't easy to drill large holes in 1/4" flat stock perfectly spaced and aligned without a large drill press. I ended up drilling smaller holes and ground them out with a carbide burr on a rotozip. All in all, there was 4 lift plates (long ones on the ends), 12 spacer plates to make, and 40 holes to drill and grind out. I'll report back when it's all installed. Honestly not sure when that is. Back out of town tomorrow for work.
Old 04-29-2019, 08:51 PM   #18
Maritime
Understood. I make do like that too. We look forward to the progress however slow it has to be. Im no better. My other crap keeps breaking down and taking my shop time.
Finally bought a lift CTScott DIY / Maintenance / Service 26 09-28-2010 10:09 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 09:35 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 09:42 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 03:33 PM
