Old 03-25-2019, 09:44 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Exhaust System Removal
Well, as cold as it is, I went out tonight for about a half hour to start my attack plan. I soaked all the manifold stud/nuts and exhaust shield components with Releasall. Removing the exhaust shield and manifold support and manifold may have to happen from both the top and the bottom, of course with the hood and wiper cowling removed. Fortunately most of the fasteners aren't rusted badly at all. Some of them are actually rust-free.
I also managed to get the stuck spring bolts at the manifold loosened and backed off. My next trip to the garage and the exhaust piping will be removed and hopefully the manifold.
These nuts should come off fairly easily, but I'll wiggle the nuts back and forth to slowly cut through the rust on the studs.
That donut looks a bit small to me! I'm amazed there wasn't an exhaust leak. It fit into the midpipe well, so I'm wondering if the Corolla and xD have slightly different manifold flanges.
Old 03-26-2019, 07:29 AM   #2
Maritime
Drives: 2008 yaris 5dr hatch
Good start, taking the manifold off to do anything there is always the risk of a broken stud, and as they say, any half hour project is 1 broken bolt away from a 3 day ordeal. may that not happen here.
Maritime is offline   Reply With Quote
Old 03-26-2019, 10:02 AM   #3
tmontague
tmontague's Avatar
Hmm, hood scoop in the near future?
Old 03-26-2019, 10:32 AM   #4
06YarisRS
Would be uber cool. When I was musing about a custom setup, I thought briefly about a TMIC and hood scoop. I actually saw a carbon fiber hood with molded hood scoop that looked awesome.
You know, since I have a 'paint booth', I suppose if I could find a scoop that suited the car, it wouldn't be that big a job to cut, mount, fill, prime and paint my own custom hood scoop. Then again, it would take away from the 'sleeper' factor. Haha.
Old 03-26-2019, 10:16 AM   #5
Maritime
+1, a functional scoop may be perfect.
Old 03-26-2019, 10:35 AM   #6
Maritime
Ha, yes, the scoop would announce loudly there are mods to the car. Although most folks would probably laugh, until you blow past at ludicrous speed and hear the woosh of the turbo LOL
Old 03-26-2019, 11:02 AM   #7
06YarisRS
LOL...practically anyone I tell that I am turboing my Yaris already laughs. All the more reason for going the sleeper route.
Old 03-26-2019, 11:58 AM   #8
Sleeper FTW!
Just don't become one of those fools who spool up for the sole purpose of advertising their blow-off.
Old 03-26-2019, 12:09 PM   #9
Maritime
Sleeper FTW!
Yep, and they are always in a friggin neon or destroyed WRX LOL
Old 03-26-2019, 01:06 PM   #10
06YarisRS
Sleeper FTW!
Little worry about that. LOL. Not really my style. An increase in performance is purely for my benefit, no one else's. Well, maybe my son. I'm sure he wouldn't mind the sensation of being pushed back in his seat a wee bit. Ssshhhh... Don't tell mom.
In all honesty, I have no interest in racing anyone. Or, showing off for anyone. I will appreciate a noticeable gain in power whilst marveling at the exquisite engineering of my little turboed car. Secondly, it will be treated with respect, because not doing so would get very expensive, very quickly.
What I might enjoy doing, when the likely occasion presents itself, is pulling away from a redneck or two that like to roll close behind you in their BIG TRUCKS. The expression on their face(s) might be gratifying.
One another note...my latest stressor - to get hung up on - is how my axles will handle the extra torque/power. I think Adam may have mentioned that in a previous post.
Old 03-26-2019, 02:36 PM   #11
tmontague
tmontague's Avatar
Your axles will likely be fine in rolling accelerations. Stay away from dropping the clutch from a stop ( you have an a/t so you can't really do that anyway lol)
With my current set up I never go wot and up to redline in first gear. Partly to protect the drive trading but mainly because with a reduced final drive there is too much torque and it spins track slicks even when they are hot
Old 03-26-2019, 02:58 PM   #12
myfirstyota
3 Yaris and counting..
My buddies golf makes 470whp with stock axles. Apparently as the story goes, don't mount slicks and you shouldn't break axles. Tire should spin before axle breaks.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 03-26-2019, 07:26 PM   #13
06YarisRS
Thanks both of you. That's reassuring about the axles. I doubt that boost in first would make much sense anyway, because with the 2ZR naturally aspirated, it wants to break loose anyway.
Old 03-27-2019, 07:24 AM   #14
Maritime
Yep I think you'll have more worry about spinning tires and loosing grip long before you break an axle.
Old 03-27-2019, 05:37 PM   #15
06YarisRS
Midpipe and Muffler Removal
Got the midpipe and axleback off.
Tomorrow - time permitting - the wiper cowl and hood will be removed. I am concerned about how to get the OEM manifold out once it's removed from the head. I'm guessing it's going to have to come out the top, or the axle is going to have to be removed. Also, the 2ZR exhaust sits a little to the right of the body channel. Fingers crossed that the 3" downpipe will line up with the channel. I may be in for some modification of the down pipe, but time will tell. Also, the manifold brace and heat shields are going to be no picnic either.
Not much done today, but I only had a half hour or so.
Hoping to clock the turbo tonight if I can get time. If so, I'll post up pics.
Old 03-27-2019, 07:49 PM   #16
myfirstyota
Anxious to see your downpipe conclusion!
Old 03-27-2019, 09:06 PM   #17
06YarisRS
Haha, me too!
Old 03-27-2019, 09:09 PM   #18
06YarisRS
Turbo Clocking
Sorry about the pic quality, and the mess in the background. My kids got off to bed without doing their cleanup. Daddy was preoccupied.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
