![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
Stock Air Intake Nuts, Bolts, Etc.
Hello,
It has been a while since I used the forums but I try to take a look every couple of months, I am glad to see this community is still standing. I am putting my Yaris back to stock and recently I removed my Injeen cold air intake and installed the stock intake. The problem is that it seems I am missing a couple of parts and the intake rattles a lot. Even if it’s not a problem, I would like to get rid of the rattle and use the proper screws as I just have some that are of the same tread pattern but not enough to keep it down, from using the picture I attached as reference I believe I need: Need 2 (90119-06859) Need 2 (N04) Need 1 (90480-18006) Need 2 (90119-08C15) Would anyone mind pointing to me if I’m missing anything else and a not too expensive place to get these parts? It seems these name are for Toyota site only as I searched for the screws on rockauto and nothing came back. |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Best bet would be a junkyard, if you can't find a Yaris at the yard then the Echo and Scion xB also use the same 1.5L 1NZ-FE engine. Toyota shares many parts across many models so you could get those fasteners from some other Toyota models just would take some time to match them up.
#3 | |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
You'll have to pick the boltsfrom the car yourself. No junk yard that I've heard of stocks the hardware
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
Knower of little
Drives: None Join Date: Jul 2019
I would highly suspect the 90119-06859 parts are just M6-1.0 flared head bolts. You can get those in pretty much any hardware store. I definitely wouldn't bother with buying OEM of such a generic part. The rubber grommet/insulators are another story though.
2ZR swap. DO IT! Ask how!
You don't have your location listed so I can't make a direct recommendation on a yard, but I would suggest starting with LKQ or Row52.com to find a place near you.
I am in the Northern Virginia area around Leesburg and am willing to travel out a bit. Will check out the sites recommended, thank you!
Unfortunately it seems most of those near me, like the ones suggested above (LKQ) don’t allow you to go pick out the hardware, the ones that do are fairly far away. Do you generally search for them online and call until you find one that allows you to do this?
Knower of little
Oh, you are super close to me. The LKQ in Mt Airy Maryland has the best selection but there are 3 other LKQs in MD and they all post their inventory online. However they've only had one yaris in the last 6 months and by the time I got there, there wasn't much left.
#11 | |
You need to go to LKQ Pick Your Part for the self-serve yards. I looked at their locator though and don't see anything in VA. Row52 may have better results.
Thank you all again for the help and advice, unfortunately, none of the options suggested above have been effective. There are Toyota Yaris available on the websites for picking my own parts but fairly far away. I was willing to drive ~50 miles to get more parts, but Yaris/XB that appeared are easily 80+ miles one way for me after searching both websites.
It seems that the next option is buying the parts from some dealer or online vendor that will ship them to me, does anyone have any suggestion on these? I have been concerned as to if there are any gotchas or specific websites I should be wary of since all of the ones I have been searching through look decent. Not sure if I can mention these in the forum. |
#14 |
Just get them from Toyota. I bet it would cost less than $20. I've always been surprised how inexpensive the hardware is from the dealer.
| F/S: Stock Intake, stock springs, and hub caps | Mister Z | Items for Sale by private party | 7 | 08-16-2010 12:26 PM |
| WTB A Stock Air Intake Also...:) | Yaryaryaris | Willing to Buy by private party | 8 | 12-21-2009 10:58 AM |
| Stock air intake setup | detroiter | Willing to Buy by private party | 2 | 12-17-2009 03:49 PM |
| Ram Air Intake? | fmicle | Performance Modifications | 6 | 11-20-2009 12:06 PM |
