Old 12-04-2009, 05:10 PM   #11
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
AND129, I think you know this by the fact that you mentioned being careful not to lift the car at this point, but it's worth mentioning for the sake of others that putting a jack under the center of the beam axle is a bad idea. It can be bent in that manner.
Neat that you were able to do this without pulling the shock bolts and removing the springs. Probably a toss-up as to which way is actually easier. (only two bolts to drop the shocks and it should make the whole process of fitting those pivot bolts a lot easier)
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
