Old 02-21-2010, 09:19 AM   #1
Falconia
Drives: Yaris 1,3 -01 Linea Luna
Do you see a Yellow wire between two green wires? If so, that yellow is the feed to the DRL module from the alternator. It is a signal that tells the DRL module that the engine is running. When the engine is off, you can still manually turn the headlights on, but the DRLs won't come on. So, disconnecting that signal should fool the DRL module into thinking that it should not turn the DRLs on.
Yes, there is yellow between two greens. I was surprised because all lights stopped working when I unplugged the DRL. If I cut that wire tail lights as well as headlights still working when I manually turn on the lights? Right?
Falconia is offline   Reply With Quote
Old 02-21-2010, 09:45 AM   #2
I believe so. To be safe, either pop the pin out of the connector, or cut the wire with enough left on the connector side to be able to reconnect if that doesn't work.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
