Old 08-28-2010, 01:39 PM   #19
Originally Posted by Nebarnix View Post
Sorry to keep bugging you and thank you for the information. Its perfect. I have one last question. On the DIY remote start wiring guide, the brake switching is listed as being on top of the brake pedal. Is that underneath the car or by the pedals?
By the pedals. Right at the top of the brake pedal.
Old 09-09-2010, 04:37 PM   #20
Nebarnix
Nebarnix's Avatar
Ok, I see the wires. But there are 5 wires (not sure why, maybe tail lights?). Do you know which wire is connected to the switch and if it is a make/break or a pull high/low type of signal?
Thanks! Remote lock / unlock with the EZ-430 chronos is so freakin great, I even have it doing the double pulse to unlock all doors with one command. I feel like James Bond (it helps that the watch beeps as I activate the locks)
Nebarnix is offline   Reply With Quote
Old 09-09-2010, 04:52 PM   #21
On that connector, Green gets pulled to 12V when the pedal is pressed.
Old 11-28-2010, 09:51 PM   #22
Nebarnix
Nebarnix's Avatar
CTScott, I am sending the final boards out to the fab in the next week or so. I will have a low power in-car wireless sensor network using 2.5Ghz 3mW nodes and a high power car to wrist watch / car to house PC using a 915Mhz 500mW link which can act as a gateway to the low power network as well as remote start and door lock unlock. The neat thing is that the low power wireless node can be used to implement additional functions in the future.
I have one question which would really simplify my design. Can IGN1 and IGN2 be tied together permanently? This would take my number of outputs from 9 to 8 which you can understand is a desirable number :)
Outputs
1 clutch sw bypass
2 ign1 / ign2
3 accessory
4 starter
5 lock
6 unlock
7 horn
8 lights
Thanks!
Old 11-28-2010, 10:08 PM   #23
Outputs
1 clutch sw bypass
2 ign1 / ign2
3 accessory
4 starter
5 lock
6 unlock
7 horn
8 lights
Thanks!
IG1 and IG2 are part of two separate circuits with two different sized fuses, so I wouldn't tie them together.
Old 12-06-2010, 12:00 PM   #24
Nebarnix
Nebarnix's Avatar
Turns out you are quite right about tying them together. bad idea.
I have found the wiring guide and gone through the schematics. It turns out that the ACC wire carries the full 30A through the key switch and is the only signal that does not trigger a relay. See pg 68-70 in the wiring guide.
I have started a page which outlines both the open universal remote start system as well as details for which wire turns on which systems.
http://wiki.nebarnix.com/wiki/Yaris_Remote_Start
So to hot wire you would
#1 Pull IG1 to 12V (and keep it there)
#2 Pull IG2 to 12V (and keep it there)
#3 Pull Starter to 12V and drop once the engine is started.
You could pull ACC to 12V as well (there is a built-in cutoff relay during cranking) but not only is it not neccesary, but you might see sparks as the circuit could pass the full 30A, though most likely it would just pass the radio current.
Thanks for all the help CTScott! I can't wait to get the boards populated and see how well it works.
Old 10-24-2015, 01:47 PM   #25
extreme.aly
Drives: Toyota Vitz 2009
Sorry for bringing back a 5 year old post back to life :p
I'm also trying to get my engine "on" wirelessly. But in my case, I'm trying to give my car both options. Turn the engine on with keys or without keys (via bluetooth).
So I want to make sure what exactly happens to the IGNITION SWITCH PINS at different states. Please correct me if i'm wrong.
At LOCK position: nothing is connected to anything
At ACC position: AM1 is connected to ACC
At On position: AM1 is connected to ACC and IG1
At Starter position: AM1 is connected to ACC and IG1, and AM2 is connected to ST2 and IG2
AM1: Yellow wire
ACC: White wire
IG1: Green wire
AM2: Gray wire
IG2: Pink wire
ST2: Black wire
Is that right?
extreme.aly is offline   Reply With Quote
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
