Old 02-23-2012, 03:54 AM   #11
yaris2010RS
yaris2010RS's Avatar
This could be a sign that your Boomslang is suffering from the same incorrect wiring that mine and a few others had. I can't recall as I am going on 2 hrs sleep in over 48 hrs right now, but it is either set to tap or intercept currently (possibly) and it should be tap I believe otherwise you will have issues. CTScott would be a great resource to PM to talk to about it. He went through my entire Bslang wire by wire to test/confirm proper termination and soldering, etc. He found several bad points and fixed them for me. He is an electrical genius if you haven't already been made aware of it and a great contributor to the community. Always willing to help.
Not saying that this is your issue for sure, but it a path to investigate.
ive read about this issue but i find it odd then that i've only gotten it twice, its not a common issue. only thing i can see possible is the connection in the harness is loose
Stock/Built Motor - Boost and Durability Yoda Forced Induction Forum 74 03-21-2012 02:18 PM
What boost gauge do you run? Bluevitz-rs Forced Induction Forum 7 07-19-2010 10:00 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 05:44 AM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 04:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 03:42 PM
