![]() Drives: yaris Join Date: Nov 2012
hello
i need this speedometer ![]() thank you |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
I have a feeling that that picture was photoshopped. That looks like the standard metric version with the inner MPH ring phtoshopped over. If you look at my video below, I am running a real one of those clusters, with a device that I created which allows the speedometer to display in MPH on the outer ring (i.e. while being pulled by a Lamborghini you would see the needle make it to the 200 MPH mark) and also increment the odometer in Miles, rather than kilometers.
http://www.youtube.com/watch?v=KkUOg...1&feature=plcp
#3 | |
advocatus diaboli
This is super sweet...is it available? BTW, beautiful scenery there!
It is available. I only made the one prototype so far, but can definitely make more as needed. The clusters are readily available on eBay, and I also have the capability now to reprogram the mileage on a used cluster to match your current cluster.
thanks CTScott
i think that , this speedometer has been photoshopped |
![]() Drives: 2007 toyota yaris sports Join Date: Oct 2010
iif i get a cluster with the tach included, will it work perfect when my car right now only has the MPH gauge
Yes. The one in my video has the tach and the car that I am running it on did not have one from the factory. The only thing that you have to make sure of it to match the "features" of your car (ABS, TRAC/VSC, etc), otherwise you will lose the indicator lights.
I dont have ABS, or Trac, i just dont like just haveing the MPH gauge i want the tach also. so its all plug and play
Yes.
#10 | |
advocatus diaboli
I have cardboard behind my indicator lights... the ones that are never going to shut off anyways. ![]()
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
ROFL, Electrical tape is the norm for this kind logic :P
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
![]() Drives: Yaris Join Date: Apr 2017
Speedometer Accuracy? | YarisPete | DIY / Maintenance / Service | 37 | 11-29-2013 02:00 PM |
Speedometer Calibration / DeMetrification | CTScott | DIY / Maintenance / Service | 17 | 10-06-2012 09:00 PM |
OEM Speedometer with tachomter | Deshi Basara | DIY / Maintenance / Service | 6 | 08-21-2012 10:11 PM |
speedometer | walt101786 | Cosmetic Modifications (Exterior/Interior) | 0 | 10-09-2010 09:03 PM |
No speedometer or tachometer lights during day | cdavidhess | DIY / Maintenance / Service | 20 | 06-30-2009 10:38 AM |
