Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 11-27-2012, 11:20 AM   #1
yazeed1989
Drives: yaris
Cool i need this speedometer
hello
thank you
yazeed1989 is offline   Reply With Quote
Old 11-27-2012, 11:48 AM   #2
I have a feeling that that picture was photoshopped. That looks like the standard metric version with the inner MPH ring phtoshopped over. If you look at my video below, I am running a real one of those clusters, with a device that I created which allows the speedometer to display in MPH on the outer ring (i.e. while being pulled by a Lamborghini you would see the needle make it to the 200 MPH mark) and also increment the odometer in Miles, rather than kilometers.
http://www.youtube.com/watch?v=KkUOg...1&feature=plcp
Old 11-27-2012, 12:17 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
This is super sweet...is it available? BTW, beautiful scenery there!
-Type 07 FFL-
My odometer 03/11
Old 11-27-2012, 12:20 PM   #4
It is available. I only made the one prototype so far, but can definitely make more as needed. The clusters are readily available on eBay, and I also have the capability now to reprogram the mileage on a used cluster to match your current cluster.
Old 11-28-2012, 03:05 AM   #5
yazeed1989
Drives: yaris
thanks CTScott
i think that , this speedometer has been photoshopped
Old 11-28-2012, 09:47 AM   #6
ajmarshall169
ajmarshall169's Avatar
Drives: 2007 toyota yaris sports
iif i get a cluster with the tach included, will it work perfect when my car right now only has the MPH gauge
ajmarshall169 is offline   Reply With Quote
Old 11-28-2012, 10:28 AM   #7
Yes. The one in my video has the tach and the car that I am running it on did not have one from the factory. The only thing that you have to make sure of it to match the "features" of your car (ABS, TRAC/VSC, etc), otherwise you will lose the indicator lights.
Old 11-28-2012, 11:00 AM   #8
ajmarshall169
I dont have ABS, or Trac, i just dont like just haveing the MPH gauge i want the tach also. so its all plug and play
Old 11-28-2012, 11:45 AM   #9
Yes.
Old 11-28-2012, 10:04 PM   #10
mazilla
advocatus diaboli
mazilla's Avatar
I have cardboard behind my indicator lights... the ones that are never going to shut off anyways.
-Type 07 FFL-
My odometer 03/11
Old 11-28-2012, 10:26 PM   #11
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
ROFL, Electrical tape is the norm for this kind logic :P
Old 06-06-2017, 01:19 AM   #12
Dohsh77
Drives: Yaris
Originally Posted by yazeed1989 View Post
hello
thank you
Are you fond it
I serch for the same speedometer
Dohsh77 is offline   Reply With Quote
Speedometer Accuracy? YarisPete DIY / Maintenance / Service 37 11-29-2013 02:00 PM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 09:00 PM
OEM Speedometer with tachomter Deshi Basara DIY / Maintenance / Service 6 08-21-2012 10:11 PM
speedometer walt101786 Cosmetic Modifications (Exterior/Interior) 0 10-09-2010 09:03 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
