Old 07-21-2013, 01:25 AM   #1315
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Picked up the tooter et plenum to runner connecting plate today. It's far beyond what I had expected! The plate fits so precisely to the runner base, I couldn't pry it off so I'll just leave there to be welded on. the hemisphere sets on a ledge and centers itself.
Now I'll do one last on the car fitting to rotate the hemisphere and mark the best attitude of the throttle body to line up with the intake.
Next, the hemisphere will be drilled to accept some aluminum tubes for the three hose fittings. Then the whole assembly goes off to the welder!
Old 07-21-2013, 03:43 AM   #1316
Astroman
Modded Moderator
Astroman's Avatar
Looks great!
Old 07-21-2013, 10:34 AM   #1317
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Tooter's Titter!
Looks like quality design and manufacturing! I'm anxious to see how it works.
Old 07-21-2013, 01:53 PM   #1318
tooter
play every day
tooter's Avatar
This is just a one-off "outside the box" experiment that will never see production because it's not cost effective. It's pure exploration just for the sake of curiosity.
Old 07-21-2013, 08:22 PM   #1319
Flipper_1938
If it makes a big number, I bet somebody will pay you to make another one.
After all, you now have a parts list (with math data).
Old 07-21-2013, 09:49 PM   #1320
tooter
play every day
tooter's Avatar
Although visually different, both plenums still hold the same 26 ounces of water. So the difference may not be that much. I'm curious as to whether a radically different plenum shape will make more gains. After a considerable amount of internet searching, as far as I know no one has ever tried anything as strange as this before. So we'll see what happens...
Old 07-22-2013, 07:54 AM   #1321
Viperoni
Drives: 2005 Toyota Echo
Looking forward to the results :)
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 07-22-2013, 10:17 AM   #1322
kou
Drives: 08 lb
This one looks a little like your design.
Old 07-22-2013, 10:30 AM   #1323
tooter
play every day
tooter's Avatar
Hey, what do you know. Someone did that design. Guess the old saying is true that there's nothing new under the sun. What car did that come off of?
Old 07-22-2013, 10:49 AM   #1324
kou
Drives: 08 lb
That manifold is off a toyota 4e-fe engine
Old 07-22-2013, 10:54 AM   #1325
tooter
play every day
tooter's Avatar
Makes sense that it would be Toyota as it's similar to the Corolla manifold. Even the mandrel bent tubing looks familiar.
Just did a search on WIKI. That manifold design was on the last 4E FE 1.5 engine which was discontinued in 1997. In 1998 the Corolla 1ZZ FE 1.8 engine carried over the similar design.
Old 07-25-2013, 07:54 PM   #1326
tooter
play every day
tooter's Avatar
The tooter et just grew some new antennae...
So now it's off to the welder!
Old 07-26-2013, 07:24 AM   #1327
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Huzzah!
Old 07-26-2013, 03:07 PM   #1328
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Awesome! alien like...
JustDidIt is offline   Reply With Quote
Old 07-29-2013, 10:21 AM   #1329
Flipper_1938
Is it done yet?
Old 07-29-2013, 04:56 PM   #1330
tooter
play every day
tooter's Avatar
It's at the welder today.
When that's done
it's ready to run.
Before dropping it off, I finished porting all of the runners and bead blasted the insides as it's the last time I'll be open to do anything to it.
For comparison, this is before porting...
I should have the tooter et up and running on the car by Friday.
Old 07-29-2013, 08:32 PM   #1331
tooter
play every day
tooter's Avatar
Came up with another idea...
TOOTER II.VII
It's for a Toyota Tacoma 2.7 4 cylinder... a 2 inch thick intake manifold spacer that makes the runners 12% longer to lower the torque curve. The prototype should be done and ready for testing in a week. I'll drive it around to let the ECU learn the new operating parameters...
...and then it's off to Harry's Dyno Shop for a few runs.
Old 07-30-2013, 05:37 PM   #1332
JustDidIt
JustDidIt's Avatar
TOOTER II.VII
Awesome!!
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
