Old 03-02-2014, 05:37 PM   #5
tylerwatts53
Drives: 07 Yaris Sedan
It sounds like the relay that controls the fuel pump is not firing. Did you verify that the fuel pump is not receiving power when you turn the ignition on?
Yes, insofar as I turned the key to ON and listened to see if I could hear the fuel pump turn on (and it did not).
Cold in Indiana? Ice in fuel line? Happened to me once many, many years ago.
Thought about that-- I did put some Heet in the gas on 2-28, and the temp. was above freezing on 3-1 while I was starting it on starting fluid.
So, if it is the fuel pump relay in the body ECU, does that mean I need to replace the body ECU? Any thoughts on how difficult/ expensive a task that is?
Thanks guys for your speedy replies!
tylerwatts53 is offline   Reply With Quote
Tags
electrical, fuel gauge, fuel pump, won't start
07 yaris lb sometimes does not start :( biggyjiggy DIY / Maintenance / Service 10 07-09-2012 05:59 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
