Old 04-17-2017, 02:31 PM   #4
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
Originally Posted by B.B._07 View Post
I took the whole piece off the car and found the problem was that there are two L shaped plastic tabs that are supposed to hook under the door seal on both sides of the b pillar. You need to peal back the door seal so you can re-seat the L shaped tabs under the seal and then just push the seal back on.
Thank you. It's just like you said it an hopefully that fixed the problem.
One of the plastic tabs was bend luckily it didn'tībreak and i could put it back under the seals.
DiCaprio is offline   Reply With Quote
Help: dealer might not be able to fix window problem (2012 Yaris) matti Third Gen Yaris General Discussion 5 01-31-2013 10:37 PM
Car Race/IDLE/initial speed Problem mamun22s DIY / Maintenance / Service 0 08-28-2012 06:29 AM
Problem with electronic door lock new-yaris-owner In Car Entertainment + Electronics (audio / video / alarm) 7 08-05-2012 05:12 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
