Old 07-09-2010, 03:28 AM   #1
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
Brief acceleration issue
I have a 2007 Toyota Yaris with 64000 miles.
Today when I was accelerating after sitting at a traffic light, I noticed my Yaris did not accelerate, rather it revved to about 4000/5000K RPM, and shuddered.
Sequence of events:
It was 95F outside when it occurred.
1. Spent 40 minutes driving 70mph on the highway.
2. Spent 5 minutes driving 35mph in the city.
3. Came to a red traffic light, braked, came to a stop to 45 seconds.
4. Placed my foot on the accelerator.
5. Car moved maybe 3-5ft, then engine started to rev to 4000/5000K RPM.
6. Car did not move, and shuddered.
7. I took my foot off the accelerator to let it go down to 0RPM, then tried again, and the car started to move.
8. I drove for maybe 1000 ft and it started again, however it was different than the first time. I pressed the accelerator, it revved a bit, and 5 seconds later it started to accelerate, but with a shudder.
9. I pulled off to a side street, let the car sit for 3-4 minutes. Continued driving and it was OK for the rest of the day.
What happened and should I be concerned that my engine or transmission is f'd up?
salmonz is offline   Reply With Quote
Old 07-09-2010, 03:31 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Automatic? Have you checked the transmission fluid level?
Old 07-09-2010, 05:01 AM   #3
sounds to me like a transmission issue too...
Old 07-09-2010, 09:41 AM   #4
brg88tx
Drives: 07 Yaris Sedan, Auto
accidently bumped it into neutral at the light?
brg88tx is offline   Reply With Quote
Old 07-09-2010, 10:45 AM   #5
Ryude
Drives: 2007 Ford Mustang GT
Converter lockup?
Ryude is offline   Reply With Quote
Old 07-09-2010, 05:36 PM   #6
salmonz
salmonz's Avatar
> Haven't checked it yet. I will look at it.
> I hope it's not.
> Nope, I don't believe I did.
Converter lockup?
> I will research more about this. I'll check the service manual.
Old 07-10-2010, 12:18 PM   #7
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
check if ur maf is plugged in correctly
Its a Chao!!!
Old 07-10-2010, 02:34 PM   #8
swidd
Drives: Yaris HB
check your floor mats! Also if you are over the age of 75, file a lawsuit!
Old 07-10-2010, 05:14 PM   #9
salmonz
salmonz's Avatar
MAF sensor is okay.
Transmission fluid is okay.
I'm under 75, but my floor mat on the driver side is missing a hook.
Old 07-11-2010, 04:40 AM   #10
matanfr
diaper change in a yaris
matanfr's Avatar
Drives: 2009 multimode hatchback 5dr
i'm having the same issues as you are having in my mmt transmission. the car is sluggish and often doesn't accelerate properly.if i read correctly, you placed your foot on the gas,the car jerked and then you removed the foot from the gas pedal?
Reading several posts about this "sluggish" yaris stuff,i think the ECU got used to highway speeds,and when you needed to accelerate from a stop,your car jerked.
try to continue the press on the gas.
"there is no secret to the balance..you just have to feel the waves.."
Heretics of dune.
matanfr is offline   Reply With Quote
Old 07-11-2010, 08:10 PM   #11
salmonz
salmonz's Avatar
The car didn't exactly jerk. I pressed the gas pedal and the car revved but no movement after 1 second. It's like the transmission slipped into neutral when it was in drive. I took my foot off the gas and tried again and then it worked properly.
About 100 ft later when there wasn't any cars around me, I pressed the gas to the floor and then immediately off, the car revved but didn't move until 3 seconds later. It was only until I came to a complete start and turned off the car, then turned it on, everything was back to normal. So maybe it was a computer issue.
Further thoughts?
By distance, I do 90% highway driving. By time, 50% highway.
Old 07-12-2010, 01:48 AM   #12
matanfr
matanfr's Avatar
i still think it's not a transmission issue but rather a sluggish ecu.do you still have a warranty? if so, ask the dealership to connect to a scanner and log any errors.
Heretics of dune.
Toyota Recalls auxmike General Yaris / Vitz Discussion 535 02-25-2021 06:13 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
more acceleration with smaller tire diameter? Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-28-2009 07:50 AM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
