Old 04-07-2019, 07:54 PM   #1
Crown
Drives: 05 Crown Victoria, 14 Yaris
Installing a hitch and towing a trailer... thoughts?
I am sure this topic has been discussed to death, I am inheriting a 2014 Yaris 3 door with 4500 miles from a close relative. I'm coming from not owning anything but 20ft long V8 Crown Victorias/Grand Marquis since my first car as a teen. This Yaris will mostly be used as an efficient commuter vehicle to keep my 50,000 mile toy Crown Vic from doing 15k a year.
I was wondering if it would be reasonable (I've read either yes or no, nothing in between lol) to tow a small trailer capable of holding a gas weed trimmer and lawn mower on the highway. Would it be better to sell the Yaris on CL and just get a small pickup? What is the going rate for these?
Thank you.
Crown is offline   Reply With Quote
Old 04-07-2019, 11:58 PM   #2
bairjo
If you are planning on using a small car to tow trailers...plan on changing your ATF often. ...if you plan on keeping the car very long. Just my opinion. Yea...there will be some fool on here that claims these cars are made for pulling trailers. They are not. Like I said...that's just my opinion. If I was looking to purchase a used Yaris, and I found one that was used for pulling trailers I would scratch it off the list.
Old 04-08-2019, 08:40 AM   #3
myfirstyota
3 Yaris and counting..
There are class I hitches available for this car. (I just installed one this past Saturday) The load rating on a class one hitch is 2000lbs trailer weight and 200 lbs tongue weight. Keep in mind the yaris is only rated for approx.1000 lbs of cargo. If you stay under 1000lbs of total trailer weight, I cant see you having much of a problem.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 04-08-2019, 09:39 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The official weight I've seen around here is 700 lbs but that's only specified for Canada. The US doesn't offer any rating for tow capacity, probably due to some liability or FMVSS issues.
I've towed a Harbor Freight 4' trailer with tires and racecar stuff for years with no issues. Probably isn't more than 250 lbs loaded. That said, I've pulled close to 1k before and it's not something you should do often. This was with the Corolla engine though and I have a manual trans as well with a higher force pressure plate, theoretically giving my drive train more capacity. Any way you slice it, you shouldn't ever exceed the gross vehicle weight rating (GWVR) which is a combination of the vehicle, fuel, passengers, cargo, etc.
The real weak point is the fact that the hitches all mount to the unibody, so you're mechanically limited to what the threaded inserts or weld points can hold.
Old 04-08-2019, 01:26 PM   #5
praivo
Drives: 2000 SCP10, 2001 NCP13
Over here the manual NCP13s are allowed to tow up to 2000 lbs if the trailer has brakes and about a half of that if not, and even the SCP10s are rated for 1000/800 lbs. The automatics are probably a bit more sensitive but <1000 lbs should still be perfectly safe to tow.
2001 Yaris 1.5 TS (NCP13), 285k km - my second car, currently being rebuilt because of rust
2000 Yaris 1.0 Terra (SCP10) - my first car and my current daily driver
praivo is offline   Reply With Quote
Old 04-08-2019, 04:43 PM   #6
myfirstyota
Basically what I was getting at. My 3 door hatch with no back seat/spare/plastic has a gvwr of 1440kg. I know the car is around 1000 kg+/-
For sheer weight, a small trailer can't be any worse on the driveline than say 4 or 5 large adults in the seats? No?!? Only disadvantage I can see is not having the extra weight over the braking wheels for traction purposes.
I think it all depends on what you're towing with a yaris. Few slicks or a lawn mower and a trimmer, like the o.p, or say that new dryer you bought... you'll *probably* be just fine.
Old 04-08-2019, 07:02 PM   #7
Look at all the hitch/towing threads that have been amassed on here over the years. A small trailer carrying a bit of lawn equipment; the Yaris will barely know it's there.
Old 04-08-2019, 09:37 PM   #8
tonynf89
Drives: 2007 Yaris 4dr Hatch
I've towed a lot of small trailer loads with my 2007 yaris hatchback, manual transmission with no issues.
Usual load is a Honda Rincon ATV.
tonynf89 is offline   Reply With Quote
Old 04-09-2019, 09:33 AM   #9
dogsridewith
Drives: 2007 2-door hatchback
You had a Corolla engine in a Yaris?
Old 04-09-2019, 10:05 AM   #10
CrankyOldMan
Have. =) 2ZR swap. Lots of threads in the performance mod section.
Anyone Have a trailer hitch on a Yaris?? Suey 1958 DIY / Maintenance / Service 58 08-05-2018 02:40 PM
Trailer Towing? Bad or worse? JustPassinThru DIY / Maintenance / Service 0 05-31-2014 10:49 PM
Genuine Toyota Hitch for Yaris now available in Canada voodoo22 DIY / Maintenance / Service 8 04-22-2014 08:50 AM
'07 Yaris LB Hidden Hitch and Trailer Pics Z00KA General Yaris / Vitz Discussion 18 04-13-2012 11:40 AM
Towing Hitch for a Yaris fmicle General Yaris / Vitz Discussion 1 05-16-2007 08:07 PM
