Old 01-23-2012, 12:14 PM   #1
My $67 sound dampening / undercoating
I have been meaning to paint the inside of the wheel wells since I bought my Yaris to get rid of the patchy look of some visible paint and some patches of seam sealer.
This Saturday I was planning on doing an oil change and figured I would do something with the wheel wells while I had it up on the lift. Doing a little research on coatings for the wheel wells, I found that Herculiner paint-on truck bed coating seemed to be a good choice. It is a urethane rubber based coating and is promoted as being for both truck bed protection and undercoating. For $67 for a gallon, I figured it was worth a shot. I wanted something that could be brushed on to avoid the mess of overspray.
I initially applied two coats to the wheel wells. I then got under the car and coated the floor pan. This morning it was done curing, so I took it out for a test run. The roads were wet and coated with sand from Saturday's snow storm. I was extremely impressed with the sound dampening that the coating provided.
Old 01-23-2012, 12:49 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Nice. Very jealous of your lift.
Old 01-23-2012, 01:03 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Additional weight?
Old 01-23-2012, 01:53 PM   #4
Additional weight?
Negligible as compared with something like dynamat. An entire gallon weighs about 10 lbs and I only used about 1/3 of the gallon. I think I have enough left to do Crashy and my Tacoma.
Old 01-23-2012, 11:39 PM   #5
fnkngrv
fnkngrv's Avatar
wow...very nice! you should coat all over crashy...haha...that would be interesting
Old 02-07-2013, 07:26 PM   #6
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Took 3 gallons for 2 thick coats on my LC
UberSilver is offline   Reply With Quote
Old 02-07-2013, 10:33 PM   #7
I just realized that it has been a year since I undercoated it. Since Crashy and my 09 are in opposite spots in the garage in preparation for the impending blizzard, I put the 09 on the lift to see how the Herculiner is surviving. Not a bit has flaked off, even with the wicked road salt around here.
Old 01-24-2012, 03:16 PM   #8
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
Additional weight?
Even if it weighed 50 lbs, it would have a negligible effect on...well, anything! I plan to do something like this soon, the road noise is bad on these cars. Thank God the engine is fairly quiet at speed.
Good job! I never thought of bed coating... It dries very hard then?
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 01-25-2012, 12:22 AM   #9
fnkngrv
fnkngrv's Avatar
Not to burst your bubble, but you are incorrect. I can attest to that easily. 50lbs is 50lbs and will affect acceleration and braking. I see a very noticeable difference rolling on 15s as opposed to my 18s as well as whether or not I have my subwoofer box in the trunk or do not. Performing a spare tire delete even makes a difference. Every change you make to a car that is designed like the Yaris has an impact and you need to weigh the pros/cons. An example is going boosted and not only that, but whether or not you go SC or turbo when you gauge your FE. You very well trade FE for power.
Old 01-25-2012, 09:51 PM   #10
Deathegg
Deathegg's Avatar
Wow, you must have a very sensitive backside if you notice the performance difference in 50 lbs. That's about 8 gallons of gas in the tank. If I take out the spare tire, my butt will not notice the difference. I would have to have a ScanGauge or similar instrumentation to tell the difference in MPG, acceleration, etc. Now, if you're talking about wheels and tires, that's a big difference in unsprung weight between 15" and 18". You'll notice that more than other weight reduction/increase.
Old 01-25-2012, 11:32 PM   #11
Viperoni
Drives: 2005 Toyota Echo
Completely correct, you're noticing the unsprung weight difference, which coutns 4-10 times more than regular weight.
I can just barely feel the difference when I pull my sub box + amp out... and it's pushing 90lbs.
CTScott, do you have any vids of your mufflerless exhaust? Just wondering how it sounds.
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 01-26-2012, 12:47 AM   #12
SAV912
Pirate Yaaaaris
SAV912's Avatar
Unsprung weight =/= dead weight. There will be a noticable difference on weight attached to parts of the car that directly handle the power vs weight somewhere else in the vehicle. That's why lighter wheels and tires are more noticable than removing the spare tire or a subwoofer.
But if you notice 50 lbs (which must be a hell of a hard hitting woofer), then more power to you. My butt dyno isn't that sensitive.
Scott, I'm thoroughly envious of your lift. And I may do the rubber brush on coating now. I've already done spray on bedliner and it made an appreciable difference, but I only did two coats on the wheel wells. I didn't do anything under the center of the car.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 02-07-2013, 05:22 PM   #13
nookandcrannycar
Performing a spare tire delete even makes a difference. .
Good to know. For everyday driving (unless going away on a trip), I'm going to remove mine. I have tire sealant and am paying extra for AAA plus coverage (longer free towing range). I've never needed either within my metro, but they'd be available if need be. Normally painless and transparent ways to increase MPG = all good in my book. I just thought (not based on more than a vague hunch really) removing it wouldn't make any difference. I trust your judgement. I don't think you would write this unless you had noticed a difference (even if it isn't much). Come to think of it, I can't remember the last time I had to put the spare to use in a car.
Old 02-07-2013, 05:53 PM   #14
nookandcrannycar
^^^^^ Oops . I just read your other posts (and other's posts) on this thread and realize the difference you are referring to = in performance not MPG. Amazingly faulty assumption on my part, especially since you are 'Mr. 143'. Re my Yaris, I am probably too clouded by MPG as a first thought.
Old 02-07-2013, 05:56 PM   #15
nookandcrannycar
^^^^^^^^^^^^^^^^^ Above (post #37 meant to appear below #36 but system posted to top of new page instead)
Old 01-26-2012, 12:10 AM   #16
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
50 lbs is noticeable in the yaris.
Old 01-23-2012, 01:43 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
nice! I went with the more traditional fatmat at 1$/sq foot lol. I used only 50ft out of the 100 i bought, but plan on using a weee bit more when it warms up for the extremely noisy engine.
Old 01-24-2012, 03:19 PM   #18
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Man, that lift is awesome...I'm drooling all over my desk!
-Type 07 FFL-
My odometer 03/11
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 03:14 AM
Sound dampening rear hatch area? m911gt DIY / Maintenance / Service 28 10-10-2013 04:39 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
Just ordered some sound dampening stuff Brad D General Yaris / Vitz Discussion 8 06-10-2009 09:09 PM
Any non-Dynamat sound dampening? vodkalush In Car Entertainment + Electronics (audio / video / alarm) 12 11-18-2006 03:32 AM
