Old 02-16-2019, 09:52 AM   #1
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I'm not sure about the 1.3 engine as we simply don't have those available in the yaris here in North America. But on the 2zr swap I did, the maf and the pipe it mounts to is removable. You'll end up with a section of pipe about 4" long with the maf mounted in it. If this happens to be your setup, maybe that oem maf tube could be integrated into the cold air setup.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 02-16-2019, 08:08 PM   #2
G.Chetcuti
Drives: Yaris T3 1.3 VVT-I 2006
Yeah unfortunately the 1.3 setup has the MAF sensor integrated into the airbox which is located right above the throttle body, so I didnt have much room to play with, because the bonnet space is already pretty limited so adding a 90 degree bend over the existing MAF housing in the airbox wouldn't fit. Hence why I opted to relocate the MAF. Alas the car is working fine as I have just driven it
G.Chetcuti is offline   Reply With Quote
cai, maf, relocation, throttle body
Gwasabi (Yoshi) - Photo-Scavenger Hunt! gwasabi Photo-Video-Media Gallery 24 03-07-2009 11:23 AM
Zefoxe - Photo Scavenger Hunt Zefoxe Photo-Video-Media Gallery 0 03-02-2009 10:23 PM
