Old 05-01-2019, 10:38 PM   #35
tmontague
tmontague's Avatar
bumping up an old thread. I was installing some subframe collars today and pulled my control arm bolts I replace 3-4 years ago. I hadn't pulled them since 3 or so years ago. Well they look brand new with zero rust on them. All I did was coat the thread and the neck of the bolt in anti seize and then coat the neck in marine grade grease. The grease squeezes out when you tighten the bolts back up but that stuff is sticky and keep the water that pools in the area from contacting the metal.
apparently this is a great method of keeping the rust away.
this is after it was wiped off, it was crazy dirty.
Torque spec on the bolt is 118 ft/lbs
*take note* the bolt neck is what corrodes and snaps off so anti seize on the threads is a good idea for corrosion resistance but it will not fix the underlying rust issue with these bolts. Coat the bolt neck in marine great which is sticky as heck and will not allow water to sit against the metal and corrode it
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
