Old 11-24-2009, 11:46 AM   #11
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
The final word on this discussion will have to wait until someone does some before and after alignment checking.
My speculation is that it simply improves the toe curve on a lowered Yaris, letting the rear suspension work more like it would at stock height. It's not gonna give you "toe out", just "less toe in".
Now... here's a question for those who have done it. (I'm freakin' lazy, could be months before I get around to it) Is there enough slop in those pivot bolts that the alignment of the rear axle becomes an issue? Can you end up "dog-tracking" due to the rear axle assembly not pointing straight along the centerline of the car? Or are they tight enough that it's not a concern? (probably another question that it will take an alignment rack to answer accurately)
Last edited by Loren; 11-24-2009 at 12:48 PM. Reason: added the word "not" that was left out
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
