![]() Drives: 2007 Yaris HB Join Date: Dec 2011
UPDATE:
Everything put back together. Fluid re-added to transmission. I'm guessing its about 0.1qt less than whatever it had at the start. Little bit spilled out before I could put the pan in place when I pulled the axle out. Little bit leaked out as I was pouring it back into the transmission. There's probably a little bit still in the pan, funnel, and tubing. Took it for a test drive. Nothing fell apart...yet. And the noise/vibration seems to be gone! The only thing I know for sure is that the passenger bearing was failing. Making a grinding noise when free spinning the wheel and noticed grease coming out of the bearing when I pulled it out of the hub. I guess mission accomplished for now..... |
| Mystery(misery?) vibration, I am determined to find a solution. | seatech30 | DIY / Maintenance / Service | 4 | 06-16-2019 06:48 PM |
| Excessive vibration over 60mph. Suspension related? | Aclosefriend | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-29-2016 06:06 PM |
| Vibration on idle & rough start | Murtaza_murti | DIY / Maintenance / Service | 25 | 08-15-2015 12:58 PM |
| Yaris vibration abnormality | talhahs | DIY / Maintenance / Service | 13 | 04-13-2013 10:07 PM |
| Pulsating Vibration | dbudworth | General Yaris / Vitz Discussion | 5 | 03-28-2011 04:06 PM |
