Old 04-05-2019, 11:20 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Why You Shouldn't Run on Empty
This Is How Much Gas You Should Be Keeping in Your Tank:
https://www.msn.com/en-us/autos/owne...cid=spartanntp
Old 04-05-2019, 03:03 PM   #2
KALISPEL II
KALISPEL II's Avatar
Drives: '22 Mazda CX-30 CE AWD 6-AT
I've always been one to fill back up somewhere between 1/4 & 1/2 tank. I don't like the thought of running out of gas while trying to make my getaway.
Plus, 13 Ways You’re Shortening the Life of Your Car:
https://www.rd.com/advice/how-youre-...dium=ad-rd-msn
2015 Toyota Yaris SE Hatchback, Super-White, 5-Speed Manual (August 2015 to August 2019)
2020 Toyota Corolla SE Sedan, Super-White, 6-Speed Manual (August 2019 to February 2022)
2022 Mazda CX-30 AWD Carbon Edition (CE), 6 Speed Automatic (February 2022 to ???)
KALISPEL II is offline   Reply With Quote
Old 04-05-2019, 03:47 PM   #3
myfirstyota
3 Yaris and counting..
I never understood the "sucking the sediment from the bottom of the tank" arguement. It's not like the pump follows the fuel level and sucks from the top of the tank. Doesn't it always suck from the bottom of the tank?!?.....but I've been wrong before.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 04-05-2019, 07:04 PM   #4
Running always low might be bad for the fuel pump.
Water sinks in the tank, so sucking up water from condensation in the tank is not a valid point, and sediments are filtered before going into the fuel line... I usually fill when it's around 1/4 or when I know I won't have enough range to do my business. Else, it gets down to E.
Sent from my CLT-L04 using Tapatalk
My Dyno Run japle Performance Modifications 11 04-10-2016 05:32 AM
TSNW 1st Annual Benefit Poker Run: Relay for Life, April 19th 2014 acrobatix Northwest 2 04-02-2014 12:09 AM
Mighty yaris dyno run! >:D Black_griffin6 Photo-Video-Media Gallery 0 01-02-2014 12:04 PM
Dealer(s) told me they needed to run my credit report even though I'm... firebird1999us New YARIS Purchase Forum 32 02-10-2009 11:08 PM
HIT AND RUN :( Pattycake Wash, Wax, Detailing, Exterior Repairs 16 12-26-2008 04:37 PM
